VB SuperShaders for Poser11 SuperFly Vol.2 [Commercial] - Just Released
VinceBagnaVinceBagna Posts: 75
edited September 2016 in Daz PA Commercial Products
Volume 2 of the VB SuperShaders for Poser11 SuperFly :)
This time you will have 158 shaders for SuperFly render engine with these categories:
1. Glass : Acrylic, Dispersion, Absorption, Ice...
2. Lights : LED, Neon, Phosphorescent...
3. Metal : Anodized, Brass, Stainless, Metal Grid, Rust...
4. Miscellaneous : Dust Cover, Hologram, Mist, Silhouette, Glowing Glass...
5. Wood : 11 woods and their painted versions
6. Bump : add bump to any SuperFly shaders in a new way for Poser. Bump different than in Vol.1
You will find a PDF tutorial included with both Volume 1 and 2 that will explain the basics of the SuperFly render engine and help you use the shaders to their max :)
1000 x 1300 - 424K
1231 x 1600 - 534K
1610 x 1288 - 557K
1610 x 1288 - 513K
1610 x 1288 - 652K
Post edited by VinceBagna on
  • XyetztXyetzt Posts: 27,546
    Cool!
  • Fantatsic!! This will be much needed as well!!
  • LeanaLeana Posts: 13,502
    Not for me as I don't have P11, but definitely looking great :)
  • xyer0xyer0 Posts: 6,507
    We need some of those for Iray: Tinted Glass, Painted Wood, Ghost, Polyurethane. Whaddaya say, Vince?
  • I'm trying to find my way with Iray, so i think i need first to get it better than now ;)
    Though i don't know if i could have in Iray a Painted Wood shader where the amount of paint can be changed. In this set, you can have the wood with more or less paint as you wish.
    Also, some of the shaders here use some tricks from the Cycles render engine (the base of the Poser11 SuperFly engine) according to the fact it is not a true PBR render engine. So i can have more "freedom" with the way light reacts with these shaders. As Iray is a PBR render engine, i'm not sure those effects could be translated.
  • VinceBagnaVinceBagna Posts: 75
    As an example, this shader Glowing Glass 02 is a glass with a glowing effect coming from the INSIDE of the surface where the shader is applied. It uses a trick in Cycles using the backfaces of the surface for the glowing part, and the front faces for the glass shader, but everything in one shader. I'm not sure Iray could do that.
    322 x 322 - 152K
    The same goes for the Hologram shaders : it uses the actual polygons of the object to draw the lines. Subdivide the object and you will get more lines. Can Iray do this?
    322 x 322 - 8K
  • I'm actually quite happy that these shaders are for Superfly smiley. I use both Poser11 and DAZ and haven't seen a lot of Superfly shaders around. This will be an instabuy for me.
    I've posted in the Freebie forum a SuperShader car paint shader that is different than those in the VB SuperShaders for Poser11 SuperFly Vol.1 ^^
    http://www.daz3d.com/forums/discussion/112076/free-poser11-superfly-carpaint-shader-vb-supershaders
    1068 x 822 - 187K
    Post edited by Chohole on
    Product looks great, VB. Many happy sales to you! I just started using Iray in May; so, I'm still finding out what its capabilities are.
    Yeah it's in the store! :D
    These look fanstastic. I left Poser behind about a year ago, but Poser definitely needs things like this. Thanks for that :). I did tell some of my Poser friends that these were here at Daz. Most of them had no idea.
    Laurie
    Post edited by AllenArt on
  • I guess it's not the first place people check at when looking for Poser content ;)
