Spot Render Question
Islandgirl
in New Users
Is there any way to do a spot render in a new window?
In Poser, if you did an area render, it would render that section in accordance to the dimensions you set for the final render. I can't seem to find a way to do that with the spot render in DS. My render dimensions are set to one thing, but the spot render will only render in the viewport which renders smaller. It would be nice to be able to just save that spot to add in postwork if I like it better than what's seen in the actual render.
With the Spot Render tool active go to the Tool Settings pane (Window>Pane(Tabs)>Tool Settings) - there you can set it to render to a new window.
Thank you very much!
