0 Opacity translucent eyeballs still showing up
Hello! I set every single part of my character model's opacity to "0", but when I render it (in Iray), translucent "eye balls" still show up, like this:
http://i.imgur.com/Ld9KNIz.png
Does anyone know how I can get rid of that?
Thank you in advance!
  • SixDsSixDs Posts: 2,384
    If you set Opacity to "0", that makes the object completely transparent (invisible). Opacity set to 100% is completely opaque = no light passes through, it is only reflected. BTW, when I try to access your image, I get a "page not found" error.
  • scorpioscorpio Posts: 8,533
    Try checking refraction and reflection and make sure they are set to 0
  • BeeMKayBeeMKay Posts: 7,019
    Have you also set Tears and Eye Moisture/Eye Reflection to 0 Opacity?
