Genx2 Exagerated Morphs
Hi everyone,
Lately, my genx2 morph transfer is causing all my new transfers to "over morph?" on the generation base figure targeted when dialed out. all the older transfer morphs dial corectly. Thanks.
695 x 623 - 91K
  • glaseyeglaseye Posts: 1,312
    Did you check the limits settings? GenX defaults the min/max setting to -10 to 10 (or -1000% to 1000%), rather then -1 to 1.
  • j_stnkj_stnk Posts: 205
    would that include the transfers i made 6 mos. ago because they dial normally? this just started to happen with any generation i tested. i read that there are issues with gen to gen3? so i progressed the morph from gen to gen2 then to gen3?  now, i did transfer morphs from gen to gen3 so i could use them on a new gen3 character from the parameter tab but i have to be careful with the values. could this be the issue? i think it probably is. umph
  • ToborTobor Posts: 2,300
    I had this happen when I accidentally doubled up on the morphs -- there are two morph files, and the dial uses both. See if you can spot any duplicates.
    thanx!  was the issue!
