Pwtoon install/usage issue
3dOutlaw3dOutlaw Posts: 2,481
So I finaly got PWToon.  I run either DS 4.7 or 4.9, but neither are applying the shader.  :(
A few questions.
First, I always install manually.  In the download there is a content folder (obvious where that goes), but there is also another folder:
Foldername:  DAZ Studio_4.5;4;4.x Public Build;4.x Private Build
Where does that go, or the stuff in it?
Second, to make sure I am tryign to apply correct...I just click a scene object (like a primitive sphere), open surfaces tab and select its material, and then double click the "pwtoon" icon in the content -> Shader Presets ->pwtoon_ds4 folder.
Then I am looking for the Pwtoon to replace the daz default shader at the top of the editor panel, and I can then apply a preset.
Post edited by 3dOutlaw on
    edited August 2016
    oops, wrong thread
    Post edited by Chohole on
    edited August 2016
    If you're not using DIM you're probably better off using the Bitrock installer.
    Post edited by fixmypcmike on
    Not sure what a Bitrock is...?
    This is from the log file:
    Loading script: V:/Hobbies/Daz/Studio/content/Shaders/pwToon_DS4/pwToon.ds
    DEBUG: "support/Poseworks/shaderDefinitions/surface/pwToonDef.ds" not found.
    Script executed successfully:
    I have copied and pasted that pwToonDef.ds file in every support fodler structure I can find.  Still gets that error  :(
    OK, I used the DIM, and that fixed it...
