Parts for Gen3
I been searching the shop, but cant find any Male Genitalia parts for.... well, ANYTHING...
Is there some kind of Mature Content filter in the shop? or was the Man Parts for M4 the only ones ever made?
    The anatomical elements since Genesis are only available in the Pro bundles.
  • MidyinMidyin Posts: 221
    thats odd. ok, thanks...
  • IkyotoIkyoto Posts: 1,159
    And the newest g3f will not show a "hip" material. Any solutions or am I stuck with non-functional genitals for g3f?
    edited October 2016
    Not sure what problem you have. With Lilith 7 after you add the anatomy, you can select either "Female Genetalia" or "Female Genetalia : Pelvis" and apply the "Lilith 7 Female Genetalia Map" and the mat will be applied and seamless. You don't need to select the surface. At least the Iray map works like this.
    Were you referring to something else or a different character? I don't have Sunny, Bethany, or Gia but all the rest work the same way.
    Post edited by fastbike1 on
    The geo-graft genitals for G3F are not UV mapped to be able to use the Torso map of the figure.  If a texture set does not include genital maps then you are out of luck.
