imported 3dmax stuff and texturing
kerabera
hello all.
i have many strange problème with working with 3dsmax and daz.
i'm building a spaceship room in 3dsmax and put some texture in it.when i import the file in .OBJ in daz3d,all the stuff is unvisible,but is here,i can select it.i'm think there is a problème whit the merging texture.
so i decide to texturing the stuff directly in daz but i have many problem to correctly size the texture.
in fact only one thing have the right preset,a little floor.
i used the tilling offset but nothing work,the texture on a wall for exemple is reduced to a little postage stamp and tilling it was completely unusable.
the room is sized at genesis character and texture is 4096x4096.
i really don't understand what happen.
1280 x 720 - 202K
Was the model UV mapped?
no it's not uv mapped because the wall is made with just basic plane.
(and when i try to open my little room in hexagon,the software crash.....what a surprise)
DS needs the model to be mapped - there are ways to set up a projection mapping, using Shader Mixer, but it's not in the default shaders (and I'm not certain it works with unmapper geometry).
ok
If this is just a plane, you might want to model it in Hexagon and add to DAZ Studio that way.
As for the scene crashing... It might happen for two reasons.
1) You somehow made a really huge prop there which is not necessary.
2) You might have some weird n-gons there. Did you make sure everything there is in quads? A common mistake I see people doing is drilling a hole into a quad surface, creating this weird 8-point, empty inside polygon and then tell Hexagon to Smooth it, which immediately crashes the program.
