DSON
I'm going absolutely crazy here.  Installed DSON made sure all of the Gen, Gen2 and Gen3 basic files are in a directory labeled genesis starter essentials.  Can't find a usable runtime from within Poser 11.
Facts:  I'm running Windows 10 with DazStudio 4.9 and Poser 11.  I want to be able to access the newer materials from DAZ in Poser because I want to export to Vue 2015.  Anyt help would be appreciated.  Library in DAZ no longer has a central runtime.
  • BeeMKayBeeMKay Posts: 7,019
    Did you install your content using DAZ Connect, or DIM? From your description, it almost sounds as if you installed using connect, which will create separate subfolders with multiple Runtimes for each product,
  • Actually almost everything was installed using DIM but Under users/public/public documents/My Daz 3D Library there arte a ton of directories some of which contain a single product.  A lot of the people are in a subdirectory called people not in a Runtime folder at all.  Not sure how Daz Studio even manages to find it all.  Mind you there are hundreds of items that were installed by older versions of Daz Studio going all the way back to version 2.3.
        Do I need to reinstall everything from scratch? :(((
  • fixmypcmikefixmypcmike Posts: 19,703
    No, just add the folder users/public/public documents/My Daz 3D Library/Runtime as a runtime folder in Poser.
  • Ty.  I'll give it a try.  Posted this in new user because although an old Daz user I'm completely new to DSON.
  • Genesis 3 is not Poser-compatible, for the others did you install the PoserCF packages as well as the DSON Core (which are the Daz Studio files)? You may need to adjust the filter settings in DIM to see those.
  • glaseyeglaseye Posts: 1,312
    By any chance Bigbear from FW?   If so long time no see ...
    Did you manage with the tips Richard Haseltine gave you? As said you also need to install the pcf (poser companion file). They contain the info that DSON needs to create the poser compatible 'stuff'. The materials by the way are poser materials. No DS materials are used in poser, so no 'new materials' from DS to Poser/Vue.....
