cr2 export options AWOL
i just got texture transformer and the tutorial says that after i load the texture i want to transfer onto M4 then to export a .cr2 file and go to file/export and new a  dialogue box will pop up called cr2 export options
when i go to file/export the cr2 export options box is a no show
i can't figure this one out.
  • fixmypcmikefixmypcmike Posts: 19,735
    WHen you click on File > Export, did you switch the pull-down in the save field for file-type to .cr2?  Then enter the filename and you should get the cr2 export options.
