M4 poses for genesis 3 characters?
Hey,
 Does anybody know how to convert m4 poses for genesis 3 males/females characters? I tried some poses to convert but nothing works. Please help thank you
  • DaWaterRatDaWaterRat Posts: 2,887
    I don't know what you're using to convert, but I'd do it in steps.  M4 to Genesis or Genesis 2, and then Genesis 2 to Genesis 3.  As I understand it, Genesis 3 only takes .duf poses, so you'l need to re-save any M4 poses in that format first, and then be prepared for a lot of adjusting.
  • carrie58carrie58 Posts: 4,171
    edited August 2016
    I'm thinking you would have to go from M4 -Genesis-Genesis2-Genesis3 ,there are pose converters for this......   http://www.daz3d.com/zev0#
    Your other option would be to do it manually ,load a M4  pose him load a Genesis 3 male and then match him up using the rotation dials on each body part .........then save as a pose ,depends on how much patience and time you have ....
    Post edited by carrie58 on
    Yep, ive done this before with V4 > G2F > G3F. The end result is not perfect but good enough so that you only have to mess with the pose just a little after applying.
    Pose converters are the only thing that works for this.  I use the v4 one to convert to gen 2 (regardless of whether it is for v4 or m4) and then the gen 2 one to convert to gen 3.
  • Cool!!! Thank you everybody for your help. I finally got the poses to work for genesis 3. Thanks again smileyyes
