Problem with Iray render
Hi everyone,
I am new on Daz, and I have a problem about lightning and Iray rendering.
I finished my scene and put 2 distant lights. The first problem that I had was about an "unknown" light coming from the left. I removed my distant lights, the headlight from my camera was on off, but this unknown light were still there. I tried to change the settings, and I finally found that this light were coming from the Render settings > Environment Mode > Dome and scene. I put "Scene only", and this light just disappeared, the problem was solved.
But now that I changes this setting, my character is completely dark when I try the render. I put again my 2 lights, I increased the intensity of the light, but it does not work, the character is still very very dark (almost black).
Someone have an idea about what is this problem, and what I can do please ?
Adjust the lights using the Luminosity parameter, with Photometric enabled. You will also probably want to adjust the Tone Mapping settings - most simply the Exposure Value - to get a better light response.
