An error occurred while reading the file, see the log for more details
gerterasmus
Hi
I need some help. Been working on a scene every evening for the past week after work, and had no problems opening it every evening. Had some work to do today, and decided to start rendering it tonight, but now it won't open.Seems like it has something to do with the hair texture. My laptop had a bit of a glitch earlier today, and now the texture map I made for the hair is not there anymore, and I can't remember what I called it.
If it told me which file was missing, I could just recreate it and save it with the original name, but this is all I can get from the log. Anyone have any ideas as to what can save my scene?
Thanks in advance.
2016-37-28 15:37:12.780 Iray INFO - module:category(MATCNV:RENDER): 1.0 MATCNV rend info : Material instance 'DS_Fraser Hair__hair1_f08_4832' uses MDL JIT compilation.
2016-37-28 15:37:12.780 WARNING: dzneuraymgr.cpp(261): Iray WARNING - module:category(MATCNV:RENDER): 1.0 MATCNV rend warn : At 'DS_Fraser Hair__hair2_f09_4857.volume.absorption_coefficient': unsupported function call: 'operator/(color,float)'
2016-37-28 15:37:12.780 Iray INFO - module:category(MATCNV:RENDER): 1.0 MATCNV rend info : Material instance 'DS_Fraser Hair__hair2_f09_4857' uses MDL JIT compilation.
2016-37-28 15:37:12.780 WARNING: dzneuraymgr.cpp(261): Iray WARNING - module:category(MATCNV:RENDER): 1.0 MATCNV rend warn : At 'DS_RH_armpits__default_f1c_4885.volume.absorption_coefficient': unsupported function call: 'operator/(color,float)'
2016-37-28 15:37:12.780 Iray INFO - module:category(MATCNV:RENDER): 1.0 MATCNV rend info : Material instance 'DS_RH_armpits__default_f1c_4885' uses MDL JIT compilation.
2016-37-28 15:37:12.796 WARNING: dzneuraymgr.cpp(261): Iray WARNING - module:category(MATCNV:RENDER): 1.0 MATCNV rend warn : At 'DS_RH_abdomen__default_f24_4951.volume.absorption_coefficient': unsupported function call: 'operator/(color,float)'
2016-37-28 15:37:12.796 Iray INFO - module:category(MATCNV:RENDER): 1.0 MATCNV rend info : Material instance 'DS_RH_abdomen__default_f24_4951' uses MDL JIT compilation.
2016-37-28 15:37:12.796 WARNING: dzneuraymgr.cpp(261): Iray WARNING - module:category(MATCNV:RENDER): 1.0 MATCNV rend warn : At 'DS_RH_v-neck__default_f25_4977.volume.absorption_coefficient': unsupported function call: 'operator/(color,float)'
2016-37-28 15:37:12.796 Iray INFO - module:category(MATCNV:RENDER): 1.0 MATCNV rend info : Material instance 'DS_RH_v-neck__default_f25_4977' uses MDL JIT compilation.
2016-37-28 15:37:12.796 WARNING: dzneuraymgr.cpp(261): Iray WARNING - module:category(MATCNV:RENDER): 1.0 MATCNV rend warn : At 'DS_RH_knuckles__default_f26_5003.volume.absorption_coefficient': unsupported function call: 'operator/(color,float)'
2016-37-28 15:37:12.796 Iray INFO - module:category(MATCNV:RENDER): 1.0 MATCNV rend info : Material instance 'DS_RH_knuckles__default_f26_5003' uses MDL JIT compilation.
2016-37-28 15:37:12.796 WARNING: dzneuraymgr.cpp(261): Iray WARNING - module:category(MATCNV:RENDER): 1.0 MATCNV rend warn : At 'DS_RH_hands__default_f27_5029.volume.absorption_coefficient': unsupported function call: 'operator/(color,float)'
2016-37-28 15:37:12.796 Iray INFO - module:category(MATCNV:RENDER): 1.0 MATCNV rend info : Material instance 'DS_RH_hands__default_f27_5029' uses MDL JIT compilation.
2016-37-28 15:37:12.796 WARNING: dzneuraymgr.cpp(261): Iray WARNING - module:category(MATCNV:RENDER): 1.0 MATCNV rend warn : At 'DS_RH_forearms__default_f28_5055.volume.absorption_coefficient': unsupported function call: 'operator/(color,float)'
2016-37-28 15:37:12.796 Iray INFO - module:category(MATCNV:RENDER): 1.0 MATCNV rend info : Material instance 'DS_RH_forearms__default_f28_5055' uses MDL JIT compilation.
2016-37-28 15:37:12.796 WARNING: dzneuraymgr.cpp(261): Iray WARNING - module:category(MATCNV:RENDER): 1.0 MATCNV rend warn : At 'DS_RH_chest__default_f29_5081.volume.absorption_coefficient': unsupported function call: 'operator/(color,float)'
