Genesis Frilled Dress
WilmapWilmap Posts: 2,917
edited November 2012 in Freebies
A Frilled Dress for Genesis.
Several textures included.
http://www.sharecg.com/v/65590/view/21/DAZ-Studio/Genesis-Frilled-Dress
600 x 600 - 186K
Post edited by Wilmap on
  • WilmapWilmap Posts: 2,917
    How about a few thank yous!!
    Thanks Wilmap!
    You make good outfits.
  • JaderailJaderail Posts: 0
    Opps, sorry just caught this thread. Thank you. I love your work because of the everyday people look you do. Not enough of it is done in my book.
    Thank you Wendy, lovely, useful items as always.
    I just grabbed them.
  • info a411info a411 Posts: 0
    Sorry if this is a stupid question, I'm a noob. Do I need some other things installed before I use this?
    DAZ is missing /data/Pusey Designs/Genesis Dresses/Frilled Dress/Dress frilled.dsf
  • carrie58carrie58 Posts: 4,176
    Thank you wilmap, looks lovely
  • Tramp GraphicsTramp Graphics Posts: 2,435
    DAZ is missing /data/Pusey Designs/Genesis Dresses/Frilled Dress/Dress frilled.dsfAll you have to do is drag the Pusey Designs folder into Documents> Daz 3D> Studio> My Library> People> Genesis> Clothing. Any further Pusey Designs outfits you download drag into that Pusey Designs folder. You drop the Textures>Pusey Designs folder into Documents> Daz 3D> Studio> My Library> People> Runtime> Textures
    Post edited by Tramp Graphics on
  • vwranglervwrangler Posts: 5,053
    Ah ... no, that's not quite right. If you do that, you'll miss the items that go into the Data folder ... which is exactly the issue the person seems to be having.
    Open the ZIP file. You should see a folder called "Genesis Frilled Dress." Open that folder. You should see three directories: data, People, Runtime. Drag ALL THREE of those folders into "My Library"; if you're on a PC, Windows will ask if you want to merge these directories. Click "Yes". That should install it. The next time you start Studio, you'll see a directory with "Pusey Designs" in the Genesis clothing directory, and the Genesis Frilled Dress should be inside that. (NOTE: I have a PC; I understand that for older versions of Mac system software, doing this may delete your existing directories rather than merging them together. If you have a Mac, someone else will need to tell you how to merge directories.)
    Open the ZIP file. You should see a folder called "Genesis Frilled Dress." Open that folder. You should see three directories: data, People, Runtime. Drag ALL THREE of those folders into "My Library"; if you're on a PC, Windows will ask if you want to merge these directories. Click "Yes". That should install it. The next time you start Studio, you'll see a directory with "Pusey Designs" in the Genesis clothing directory, and the Genesis Frilled Dress should be inside that. (NOTE: I have a PC; I understand that for older versions of Mac system software, doing this may delete your existing directories rather than merging them together. If you have a Mac, someone else will need to tell you how to merge directories.)If he';s on a pre-Lion Mac, he'll need to manually put each folder into the proper folder within the My Library folder. So, it's a simple matter of, in addition to placing placing the afforementioned folders within their proper subfolder within My Library> People, also put the content of the Data folder within the My Library> Data folder. "Merging" folders isn't always an option.
    There seems to be an error in the way the 'data' folder is set up.
    There are two folders called Genesis Frilled Dress. Is that correct Wendy?
    410 x 498 - 118K
    That is how it is on my PC. Why there are two folders I don't know. Does it work like that or should it be amended?
    No, it doesn't work Wendy. I get the error shown below when I try to load the file called 'Frilled Dress.DSF' from the Content Library tab.
    462 x 304 - 77K
    Ok, have altered that and updated the file.
    I had two frilled dresses and had put the wrong one in the folder! Sorry about that!
    That works fine now Wendy.
    Thank you very much for fixing it.
  • ThatGuyThatGuy Posts: 797
    thank you very much for continuing to create wonderful clothing for Genesis.
  • KalypsoKalypso Posts: 210
    Very nice dress! I have the DSON importer, will this work in Poser?
  • Alisa Uh-LisaAlisa Uh-Lisa Posts: 1,310
    Lovely - thanks so much!
  • Lord_AshesLord_Ashes Posts: 91
    I like the dress but initially I had problems using it with the Daz Animations. The top of the dress would stay rigid so if the actor was kneeling, bowing, etc the actor would "rip out" of the top of the dress.
    However, I was able to fix this problem by exporting and importing the dress (maybe this step was not necessary) and then using the Transfer Utility to re-rig the dress using the "Bodysuit - Loose" template.
    This seemed to have resolved my issue.
