Flat colours in Carrara
Hi
How do I render an object so that it looks completely flat in Carrara
I'd like to create the same effect I asked about in this question regarding Daz studio 4.5
http://www.daz3d.com/forums/discussion/5420/
any help would be appreciated
thanks
Post edited by Sonofbelmont on
- In Scene/Filters add "Toon! part III". Edit and set Shadow to white and "Line Effect" to 0%.
- Or, if you own Carrara Pro, got to the Output tab in the Render room and add "Material Diffuse" in "Multi Pass".
Render in both cases as usual with the photorealistic renderer.
Edit:
- In "Toon! part II", set also "Shadow Size" and "Highlight Size" to 0%.
Both methods render also a texture in the color channel of a shader. If you needed a plain color, you would have to replace "Texture Map" by "Color" in every shader that's visible in the render...
