Deformers Plus: TailorMe
Hi
I recenlty purchased Deformers Plus: Tailer Me - http://www.daz3d.com/deformers-plus-tailorme
The issue I am having is either a user issue:) or something is up.
I have tried this on DAZ 4.9 and 4.9 Beta
When I load in an outfit and then go to contentLibrary>products>D>Deformers Plus: Tailerme I see all the items
When I select my outfit then load or double click the item I get an error
SEE ATTACHED FILE FOR DETAILS
2016-08-25 16:01:35.313 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-08-25 16:01:35.315 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-08-25 16:01:35.880 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-08-25 16:01:35.881 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-08-25 16:01:47.089 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-08-25 16:01:47.098 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-08-25 16:01:47.104 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-08-25 16:01:48.767 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-08-25 16:01:48.775 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-08-25 16:01:48.784 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-08-25 16:01:48.788 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-08-25 16:01:48.791 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-08-25 16:01:48.799 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-08-25 16:01:48.808 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-08-25 16:01:48.819 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-08-25 16:01:48.827 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-08-25 16:01:48.837 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-08-25 16:03:02.343 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
2016-08-25 16:03:45.551 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-08-25 16:03:45.552 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-08-25 16:03:45.553 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-08-25 16:03:45.623 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-08-25 16:03:45.624 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-08-25 16:03:45.717 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-08-25 16:03:45.718 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-08-25 16:03:46.228 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-08-25 16:03:47.695 File loaded in 0 min 0.2 sec.
2016-08-25 16:03:47.696 Loaded file: jacket.duf
2016-08-25 16:03:47.834 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-08-25 16:03:48.169 Loaded image mJacket-01.jpg
2016-08-25 16:05:31.214 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
2016-08-25 16:05:33.346 Importing File...
2016-08-25 16:05:33.346 Importing ring_ytranspos.pp2 ...
2016-08-25 16:05:33.374 Reading ballball.obj
2016-08-25 16:05:35.013 Error occurred while importing file. See the log file for details.
  • Richard HaseltineRichard Haseltine Posts: 111,769
    edited August 2016
    What did you have selected when you loaded the Deformers? The libpng errors are not significant and can be ignored.
  • I had selected the actual clothing item that i want to deform. If I dont select an item then it doesnt hae anything to deform.
    Daz shows that error but I cannot close it - I have to ctrl alt delete (task manager) quit daz after that error
    I tried this in daz 4.6 and 4.9 and 4.9 beta
    I also tried rebuilding my database etc
  • I see the same issue, if I use them with Genesis # - they work with older figures, such as Victoria 4. It may be that the product doesn't work with weight-mapped figures, I would open a support ticket so this can be looked into.
