Looking for a particular item
Hello everyone,
It may be a strange request because I haven't been able to find anything out there, but I'm looking for a package of drugs of some kind. I'm doing a crime scene where the cops find a package of drugs. I was thinking like a pound sized pouch that is wrapped in seran wrap. I was hoping for something that looks like cocaine or heroine, but marijiuana or something else will work. Like I said I know it seems like a strange request, but it is kind of crucial to the story line and I can't seem to find it anywhere.
Thanks in advance
  • 3Diva3Diva Posts: 12,058
    That's a tough one, I've never seen anything like that before. I wish you luck! :)
    You might have to pay an artist to model something for you. A 3D seran wrapped brick of heroine doesn't sound like it would be too hard for a 3D sculpter (I definitely could be wrong about that though, as I don't have a lot of experience with sculpting models).
  • Charlie JudgeCharlie Judge Posts: 13,645
    edited August 2016
  • I saw that paraphernalia one earlier. Unfortunately, it's not quite what I'm looking for. THe packets look a bit closer to what I was looking for, they are just a bit more than I was looking to spend for them. I may have to try to commission someone to make it for me, unfortunately, I don't really know anyone to do so.
  • Pack58Pack58 Posts: 750
    Have you seen the coflek-gnorg Drug Den at Rendo?
    Could you take something like this: http://laticis.deviantart.com/art/FREE-DAZ-Prop-Morphing-Fantasy-Rock-452194949 and use a different shader on it to give it the apperance of a seran wraped package?
  • Something like this?
    1295 x 700 - 1M
    Is there a web photo you could share to show us what you're looking for?
  • This is the closest this I can find online.
    453 x 203 - 10K
    That's pretty much it there. Where can that be found?
    Did you check out "Drug Den" that Pack58 suggested: https://www.renderosity.com/mod/bcs/drug-den/110052/ ? There are packets like that in it.
    I didn't even see that post. I must have scanned over it accidently. Those are perfect, I just wish it was a little bit less expensive. I won't be using the rest of the environment and I have already spent wuite a bit on this project. I may have to see if I can swing it, unless somebody knows about a freebie or something a little bit less.
    edited August 2016
    There is a one off 18% coupon somewhere from the main page. That will bring it down to just under $10.00. Nothing like the savings you can get here but maybe enough in this case? And there is a MAC 10 in the set, weren't you looking for a silenced handgun a while back?
    Post edited by Pack58 on
    If you are registered there you should see an 18% off coupon somewhere from the main page. That will bring it down to just under $10.00. Nothing like the savings you can get here but maybe enough in this case? And there is a MAC 10 in the set, weren't you looking for a silenced handgun a while back?
    I'm not registered. I'll have to do that. I was looking for a silencer gun, more of a handgun though, but I found one. Thank you for you help.
    "More of a pistol" I meant to say
    I made it up in Daz. It's two props - a bar of soap inside a cushion. Scaled them to the size I wanted, then put a white plastic shader on the soap and a clear plastic shader on the cushion. It's a bit 'glossy' but you could probably tweak that in the settings.
    I made it up in Daz. It's two props - a bar of soap inside a cushion. Scaled them to the size I wanted, then put a white plastic shader on the soap and a clear plastic shader on the cushion. It's a bit 'glossy' but you could probaQuite bly tweak that in the settings.
    Quite inventive. I'll have to try something like that and see how it comes out.
  • Rakshi Games has a free bag pile on ShareCG: http://www.sharecg.com/v/82880/browse/5/3D-Model/Free-Bag-Pile
    Quick render...
  • I'll try that again...
    1063 x 703 - 1M
