I cannot fix the PBM Breasts Cleavage with custom morph
Hello,
I'm learning DAZ Studio to create clothes and I'm facing a problem: fixing the breasts cleavage morph of my cloth for G3F doesn't work.
I follow some tutorials and here's what I do:
- load G3F
- import the top at OBJ file
- Transfer Utility: G3F to my top (called Fitness Top)
- then I fit my Fitness Top to G3F with parenting
- now I use Morph Loader Pro to import the fix for PBMBreastsCleavage, with Reverse Deformation: YES and Overwrite Existing: Deltas and ERC links.
- result: the PBMBreastCleavage morph is still the original one...
I verified several times, my OBJ file has been exported from Blender correctly, with the correct name (PBMBreastsCleavage). Also, I imported several other morphs, which works correctly with the method I use. That's why I don't understand what's wrong here.
Thanks in advance if you can help me :)
Had you applied the cleavage morph to the base figure before loading the morph in the clothes? If so, zero it, select the clothing, and then go to Edit>Figure>Clear Generated Morphs before you load your custom morph (I'm not sure this is needed, but auto-generated morphs have caused confusion for me in the past so it's worth trying).
When I import morphs, G3F has no morph (all setted to 0%). And unfortunately, clearing generated morphs doesn't help here...
Also I'm wondering: when I use the Transfer Utility to my clothes, where can I see all the morphs generated?
And I even looked at some products that support this morph, and it works fine on them.
edit:
Finally I succeed to create the morph :)
First I thought it was because I worked on my iMac, then I tried on my PC. I created the top figure from scratch by importing the OBJ file, then Transfer Utility and Morph Loader. The morph I imported (Breasts Size) didn't work this time. I checked again the settings several times and it didn't work either.
Then I tried to delete the morph from the Parameters (edit mode enabled) and then the morph actually disapeared (G3F breasts grows but not the top). So I imported the morph again via Morph Loader, with BS morph active on G3F this time and the morph on the top applied immediately.
So I did the same for the Breasts Cleavage, and this time it works.
Thank you Richard for your help :)
If I remember correctly, you have to twitch changed morph in order to see changes in view port. When you change active (already dialed) morph with transfer utility, nothing in your view port will change. You have to go to parameters tab, to the morph you changed and dial it back and forwards some in order to see the change.
Dial it back and forward, I did it too, but it didn't work. Actually, the only method that works 100% to me is to delete the current morph before loading the custom one.
