Laguna Mermaid wierd actions - Solved (sort of)
Charlie JudgeCharlie Judge Posts: 13,628
edited August 2016 in The Commons
Out of the box loaded on Genesis 3 looks and renders wierd in the load/create tab. But just shift to the surface tab without making any adjustments and it looks and renders more or less as expected. Shift back to rthe load/create tab and the wierd configuration shows up again. I'm using 64 bit windows 7, Daz Studio 4.9 and rendering in 3DL; but I get similar results with Iray
Does anybody know what is happening here or have any suggestions?
1525 x 849 - 69K
1130 x 849 - 105K
Post edited by Charlie Judge on
  • Charlie JudgeCharlie Judge Posts: 13,628
    edited August 2016
    Thanks for the reply but while it address the white band it doesn't seem to explain why I am seeing two entirely different things in the load/create tab and the surfacing tab.
    OK. I'm not really sure what caused the problem in the first place but now it seems to be fixed. I played around with viewport options and changing styles back and forth. wound up resetting defaults and then customising again. I don't really know exactly what fixed it but anyway I don't see the problem anymore.
    I'm still curious what the problem was with seeing and rendering wrong in the load tab and the pose tab but having the correct view in the other tabs
