Transfer Utility and Injection Channels
3dOutlaw3dOutlaw Posts: 2,481
I have solved my problems using the Transfer Utility for transferring morphs from V4 to Genesis, when using morphs like Bodybuilder, Utopian, etc.
What I am having problems with are morphs that show up as a community Injection Channel.
When I run the Transfer Utility, these do not appear in Genesis, coming from V4.
What is different for these, and is there a way to convert/move something here, that these will transfer?
Thanks!
    Forget it, I figured it out as well...using an export/import of an OBJ.
    Results, if interested: http://pickled-papaya.com/home/?page_id=17&did=2
  • Richard HaseltineRichard Haseltine Posts: 111,332
    Were the morphs injected when you ran the Transfer utility?
    NO they did not show up, if they were in the Injection Channel area...so instead I exported/imported them in as a new morph, and then went from there. It worked that way. Just as good, just a little more work.
