Daz4,9 can't see files in my 3. database.
With 4.9 my 3. directories are visible but none of the files. Does anyone know why?
In the past migrating the old data base worked fine.
Now under the content tab, catagories, I see all the directories but none of the files.
Thanks for your help.
Which version were you using before? Are the files missing in the Content Library pane and the Smart Content pane, or only in one? If only one please post a screenshot of the affected pane.
I have never used the Smart Content pane. I found the Content Library pane easier to use.
Which version of DS were you using before? Is this the first version of DS 4 you have installed? If not were you previosuly using PostgtreSQL or Valentina?
I had DS 4.7 installed
And were you using PostgreSQL or Valentina? 4.7 would allow either.
