My entire content library vanished.
My entire content library vanished. The window is entirely empty. I tried searching the hard drive for files and it returned nothing. Same result for known directories. It was fine one minute.. then just poofed.
I do have a huge database sorted in 2 base directories. Both are listed in the Content Directory Manager.
Ideas?
2048 x 1125 - 172K
  • fastbike1fastbike1 Posts: 4,084
    Did you go to the listed directorys using Windows Explorer? If so, are the directories there? I would guess they are. If you paths are correct, it sounds like something happened to the CMS database.
  • You have collapsed the folder list. Look above the None at the top of the empty area - there are two dark areas in the middle of the narrow bars runing across the pane, click the lower to reshow the folder list.
  • Ohhh.. thank you.. did not even see that. Fixed now :)
