Should Multi GPU mode be disabled or enabled in GPU ???
Morphious-2630405
I have an Nvidia GeForce 690 which has a dual GPU. What setting should I use for Optimum rendering? Thanks.
Are you rendering in Iray? I would check and see if you are splitting the vram on your card between both gpu's. You have 4gb of Vram on this card and 3000 cuda cores total. This is a nice card if you are not splitting the video ram between the cards! If it is split you will have to keep your scenes under 2gb or turn off one of the cores to use less cuda cores but have more video ram for your scenes.
Be sure to disable SLI in the Nvidia control panel. Daz Studio renders Iray more efficiently when this is turned off.
