PwToon not working in DS 4.5.0.114 Pro?
DisparateDreamer
So, I have Daz Pro version 4.5.0.114.
I have the newest version of pwToon, for Daz 4, installed and YES its the folders labled for DS4.
I redownloaded and reinstalled just in case.
But it's not working.
I click the presets and nothing applies.
The PwEffects don't work either, the pwCatch doesn't work, none of them work. None of the extra settings appear, no shader is being applied. It's broken!!!
I'm stumped. pwCatch worked partially in 4..... gimpy but kind of worked. So do none of them work in 4.5??? dammit. I need those things to work. Grr. :(
*headscratch* It worked for me when I had .114 installed, and right now works in 4.5.1.6 too. You have an item picked and the surfaces you want to shade picked too, right? (Checking, 'cause I've forgotten to do that couple of times myself.) Can you upgrade to 4.5.1.6? If not, recompiling the shaders might help, too.
Here's a thread about pwShaders: http://www.daz3d.com/forums/discussion/9382/
And here's how to recompile shaders: http://www.daz3d.com/forums/viewreply/129239/
(Note: you will want to copy shaderdl.exe into each directory where shaders reside, less of a hassle that way.)
It may be a silly question, but are you selecting the area to be affected by the shader in the surface tab, then selecting the preset?
Did you apply the Neutral (white circle icon) preset first?
