Daz Studio become really slowly
Hi... i've been working on a scenary with a lot of props with no problem til yesterday, Now I load that scenario and try to load every figure with a merge and that merge takes about 1 hour until the figure shows in the scene ans then, it takes about 10 minutes or more betwee you do every operation, selctingm deleting, moving... is impossible to work with daz studio. why this can't be now suddenly?
I'm working on a i5 with 8gb ram, nvidia 960 4gb and windows 10 64 bits and the DS takes only 2gb ram as I can see in the process manager.
Thanks
  • barbultbarbult Posts: 27,477
    edited August 2016
    One thing that will make the viewport very slow is Interactive Update on Smoothing. Some clothing products in the store set Interactive Update ON. I always turn it OFF if I see that. I don't know if that would make a merge slow, though.
    Post edited by barbult on
  • I don't know but this scene had worked til now. Is like the DS has a problem with his own files. I can't determine where is the issue. I've merged two models with 2 figures and is ok, but anothe file with only one figure takes more than 30 minutes and it hangs the DS. But nevertheless, the model loads ok in a normal file loading.
  • Have you changed the viewport preview mode? Have you had a video driver update?
  • Nop, drivers are correctly installed and updated. When finally you can move something, it moves smooth, the problem is the general performance of the DS
