- FIXED - Mouse quit working
Just installed DS 4.9 today and everything worked. After closing DAZ and later reopening, my mouse quit working on the interface. I can't use keyboard shortcuts either. I can't use the interface at all. The log follows:
2016-19-09 17:19:15.786 WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
2016-19-09 17:19:15.786 3D mouse support library could not be loaded.
2016-19-09 17:19:15.786 Creating Main Window...
2016-19-09 17:19:15.786 Creating Viewport Manager...
2016-19-09 17:19:15.864 Successfully created OpenGL viewport for Viewport1.
2016-19-09 17:19:16.144 Successfully created OpenGL viewport for Viewport2.
2016-19-09 17:19:16.269 Successfully created OpenGL viewport for Viewport3.
2016-19-09 17:19:16.425 Successfully created OpenGL viewport for Viewport4.
2016-19-09 17:19:16.612 Creating Action Manager...
2016-19-09 17:19:16.628 Creating Pane Manager...
2016-19-09 17:19:16.971 Successfully created OpenGL viewport for AuxViewportView.
2016-19-09 17:19:18.328 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2016-19-09 17:19:18.476 Executing startup script...
2016-19-09 17:19:18.497 Started in: C:/Program Files/DAZ 3D/DAZStudio4
EDIT: Solved
The problem was due to mutliple monitors. DAZ pop-up windows, check "do not to show this at startup", were popping up in another monitor than the main interface. Since you have to close the pop up before you can interact with the main interface it appeared not to recognize the mouse or keyboard.
