Colm Jackson's ProStudio HDR pack - error
This product here, just bought it: http://www.daz3d.com/pro-studio-hdr-lighting-system Installed thru DIM, reloaded DS, and tried to load Light05L and i'm getting the following error:
Could not find file: /Runtime/Textures/Colm Jackson/Render Studio/ProStudioHDR/Light05L.exr
What'd i do wrong ??
  • evilded777evilded777 Posts: 2,551
    You may not have done anything wrong. You should probably report this as possibly a file missing, and I'm sure tech support will help you.
  • namffuaknamffuak Posts: 4,533
    I get the same eror - and if I click on 'locate' and walk the path it says doesn't work - the file is there and is accepted. Not sure just what is going on here.
  • TottallouTottallou Posts: 555
    This puzzled me at first but then I noticed there is a space in the path of the file - /Runtime/Textures/Colm Jackson/Render Studio/ ProStudioHDR/Light05L.exr
    Did you by chance submit a ticket, reporting that path error?     If not, do you think that you could do so please.
  • Jan19Jan19 Posts: 1,109
    This may have been corrected already.  I installed from the Product Library, and got the same error.
    Installing through Connect will put all the files in the right place.
    Showed as updated in DIM today and the paths look to be fixed.
