Genesis3,2,1 Clothing to M4 and V4 (is there a product for this?)
I know I can auto fit M4 and V4 clothing to G1, G2, G3, but I can't seem to find anything that lets me go the other way.
Does anybody know of a product that will do this?
JD
  • evilded777evilded777 Posts: 2,545
    No, there really isn't it.
    Maybe Cross Dresser, but I haven't kept up with that product in a long time.
  • HavosHavos Posts: 5,703
    There is also Wardrobe Wizard. This has a Genesis plug in, aswell as M4/V4. So you can convert from Genesis to M4 or V4. For Genesis 2 and 3 clothing, you would need to autofit to Genesis first, and then convert that.
    If you have Poser, this has Wardrobe Wizard built in, so you would just need to buy the three plug-ins.
    If you have Poser 10 or higher, another option is the fitting room to convert the clothing to the older models.
    I would be wary of the plugin, it was made back before the DSON importer was made and hasn't been updated since, so it may not work with genesis considering it was made before there was actually an official way to get it working in Poser.
    I am pretty sure Wardrobe Wizard requires the item to be converted to be a poser CR2 file. As such, any Genesis clothing would need to be exported as CR2 from DS, and then converted to a M4/V4 CR2 using either the WW standalone app, or the one inside Poser. How well it works will vary, but the DSON importer would not be needed in either case.
    edited August 2016
    What I'm saying is that it was made before anything official was released, hence the way it reads the cr2 may be wrong and the resulting conversion would be wrong. So far I haven't heard anyone getting any results from the plugin, only the fitting room.
    Post edited by Male-M3dia on
    I was never impressed with the results of Wardrobe Wizard. I mean... I saw some great conversions, but I never MADE a great conversion. Cross Dresser, in my opinion, was much better for what it did. Never bothered with the Fitting Room, I had mostly left Poser behind by the time that was added.
