Right click not working
Right clicking in the viewport suddenly stopped working...
It works everywhere else in the user interface and brings up the appropriate context menu, but when I try to right click on an object in the viewport... nothing happens!
Is there some setting somewhere I accidentally changed that disables right click in viewport?
(DAZ Studio 4.9.2.70, 64 bit)
Which tool is active? Is the viewport actually there?
OK, I see what happened now... No tool whatsoever was active.
Never experienced that before, I always had some tool active... even if it have been the wrong one from time to time!
(I'm a Poser convert, still trying to get used to the DS interface...
Hmm, I thought there was always an active tool too. Surprising.
OK, yes there will always be an active tool - were you looking at the Tool menu to check, or going by the toolbar? Not every tool will appear in the toolbar (depending on which layout you use), so it is possible to have no button highlighted. I just checked and of the tools I have the Scene Navigator, Region navigator, Spot Render, and AniMate 2 tools lack right-click menus.
Thanks, this worked great! I had switched from 'Node Selection Tool' to 'Scene Navigator Tool' and there is no right click menu for the former.
Basically, if you lose your right click menu switch tools from toolbar or menu.
