Morphs not loading Poser 9
ArhainArt(RWS)
I just got a new comp and installed Poser 9. All files installed, but the morphs for V4, A4, S4, G4 and M4 will not load into the figures.
My OS is Windows 10.
Any help is appreciated.
Thanks
To which folder did you install - you must not use the application folder in WIndows Vista or later. If you installed manually did you then go to \Runtime\Libraries\!DAZ in the install location and run the DzCreateExPFiles-v4.bat and DzCreateExPFiles-m4.bat scripts?
Install manager will, I think, run the batch file for you so it's only for manual installs thatb this should be needed. The old Bitrock installers would not, as I recall, run the batch file - they did, though, place a shorcut on the desktop so it was more obvious that it needed to be done.
