Why are mirrors so dark in Daz3D?
joelmarkleejoelmarklee Posts: 19
edited August 2016 in New Users
Why are mirrors so dark when I render in Daz3D?  My basic problem is that I have to intensely light my objects in order for them to be reflected in mirrors.  So much so, that the lighting completely washes the object out when observed directly.  The result is that if I crank up the lights enough, I'll get a good reflection in the mirror, but parts of the object observed directly will be very white / washed out.  I don't want to have to make it look like my objects are in a bright spot light just to be seen in mirrors!
I hope that makes sense.  Are there any settings for the mirror that I should look at?  I am currently using the settings recommended by Miss B in this thread:
http://www.daz3d.com/forums/discussion/38595/reflections-in-a-mirror-solved
Thanks!
Post edited by joelmarklee on
  • evilded777evilded777 Posts: 2,551
    Iray or 3Delight?
    We won't get anywhere without knowing what you are really trying to do.
  • Iray.  I'm just trying to get a mirror...any mirror...to work as expected.  When I use mirrors, I find that objects in the mirror are not visible (or appear very dark) unless intensely lighted.
  • Ah... it does seem to be a problem with Iray.  With 3Delight, the mirror surfaces seem to work as expected.  In an Iray render, the mirror looks very dark (blackish) and figures do not show up in the mirror unless intensely lit.  The reflection is also blurry in Iray, vs. crisp in 3Delight.
    Is there something I can do to fix mirrors in my Iray renders?
  • Found my answer:
    https://helpdaz.zendesk.com/hc/en-us/articles/207530543-Getting-reflections-in-mirrors-in-iray
    Thanks for pointing me in the direction of the render engine.
  • BeeMKayBeeMKay Posts: 7,019
    edited August 2016
    The settings MissB gave are for 3Delight mirrors. That's why it worked in 3DL, but not in Iray. If you aresearching for settings in the forum, be careful about the posting date. Anything before 2015 is most likely 3Delight. Iray only entered the picture in 2015.
    Post edited by BeeMKay on
  • frank0314frank0314 Posts: 15,116
    Whenever rendering mirrors you need to have the proper lighting.
