How to save Zbrush Morph in Different folder?
Hi Dumb question, but here goes:
I created a morph in Zbrush for genesis 3F, then I loaded it in using morph loader pro. So it shows up under morph loader pro. I then selected the morph and did "save as" > "support asset" > "morph asset".
I was expecting it to offer me a place to save it but it didn't, it just went ahead and saved it.
So that's cool, the morph is saved but it's stuck in the "morph loader pro" folder.
Other people have morphs under e.g. "Actor" > "Head" etc.
SO: How do I save the morph into a different folder than where it loads in under morph loader pro?
Thanks in advance for any advice
  • You may need to enable the Advanced options dialogue for GoZ - in Edit>Preferences>Interface in the Release version of DS, or Edit>Preferences>Bridges for the current beta. Once enabled you should be able to expand the options under the morph and right-click on the path to chnage it.
  • Cris PalominoCris Palomino Posts: 13,020
    When you loaded the morph with Morph Loader Pro, it would appear you left the default setting for the path under Property Group.  You can set it there by right-clicking the field and choosing or editing the field itself manually.
    However, if you have loaded it and want it somewhere else, you can click on the Gear icon on the dial.  There you will see the path..  You can input the location you prefer
  • bodzettebodzette Posts: 13
    Awesome! Thank you guys.
