Puppeteer Panel
OldminerOldminer Posts: 135
edited October 2012 in Daz Studio Discussion
Is there a way to lock the Puppeteer Panel so it stays visible on the Pose/Animate window when you select another figure and then return to the original. I want to use camera and light puppeteer panels as well as my main figure puppeteer. I have tried the always on top on and off on works as long a you don't select another figure..
Post edited by Oldminer on
  • cridgitcridgit Posts: 1,765
    edited May 2022
    Redacted
    Post edited by cridgit on
    I think, it depend on what type layout you use. but about every layout, you can customize easily,
    eg when you select ,"pose /Animate"activity , you want to show and fix the "puppeteer" in one of contena?
    you just drag the puppeter window(tab) to the contena where you want .
    or mergin area of each contena (tabs), right click, then select "Add pane"
    choose "puppeteer"
    and you want to save the layout, on top menu window>work space>save layout eg "animattion layout"
    767 x 668 - 68K
  • OldminerOldminer Posts: 135
    Thanks all, I got what I needed and can now dock the Puppeteer panel as needed and your right this solves keeping it available.
