First Class Stateroom issue
Testing6790Testing6790 Posts: 1,091
http://www.daz3d.com/shop/first-class-stateroom/
I have this installed in my c:/Daz Content folder, but I cannot find it at all in my running DS libraries. It is in my
"C:\DAZ Content\Runtime\libraries\Character\StateRoom" folder in windows explorer, and I can drag-and-drop them into my running DS and it works fine.
I've tried re-installing multiple times.
  • fixmypcmikefixmypcmike Posts: 19,725
    Does it show up in Content Library > Poser Formats > DAZ Content > Figures > StateRoom?
  • Testing6790Testing6790 Posts: 1,091
    I will check when I get home, but I can venture to guess, "no." I used the search feature on the root directory (I'm not sure if you need to be selecting the dir you want to search so I play it safe and go to the top) and nothing shows up.
    If you aren't seeing it there, can you go to Edit > Preferences > Content Library > Content Directory Manager, expand the DS-formats and Poser-formats sections, and post a screenshot?
    By that I mean inside DS, not in Windows Explorer.
  • DAZ_bfurnerDAZ_bfurner Posts: 62
    There is a readme pdf file in the doc center found here: http://docs.daz3d.com/doku.php/?do=googlecustomsearch&id=First+Class+Stateroom
    I hope this will help.
  • Daz Jack TomalinDaz Jack Tomalin Posts: 13,988
    Hey,
    I've just checked, and as far as I can see - this pre-dates full DS support. So the only thing that is included are DS mats. Since you have to load the cr2's, you need to make sure that Runtime folder is added correctly as fixmypcmike said.
    Hope that helps :)
    edited October 2012
    http://i45.tinypic.com/2ibkj1z.png
    Edit: I added the runtime, but when I go to the stateroom folder in charaters, the folder is empty. In DS that is.
    Post edited by Testing6790 on
    I think it's the nested content folders screwing things up -- you should never have a folder and a subfolder of that folder both listed. Choose either "DAZ Content" or "DAZ Content\My Library" and only install to that location.
