How to see textures in zbrush?
edited July 2016 in The Commons
There is a way to see the objects and figures in zbrush texture shaded like daz? The objects that I use in zbrush are from daz.
Pd. I have a little problem with zbrush. I can't re-send the files to daz. When I push the Goz button It's say "File saved to disk successfully" What I'm doing wrong?
Many thanks
Post edited by Super cheese sandwich on
  • Richard HaseltineRichard Haseltine Posts: 111,348
    GoZ does not send textures, or the Surface groups that may be needed to make them work. If you want to work with textures you would probably be better off using an OBJ exported from DS and imported into ZBrush, setting it to read materials as groups. You would then need to import the textures and apply them to the divided model as Polypaint. Doing that with the Daz humans, where different areas of the model use different maps that overlap in the UV square, can take a bit of fiddling.
    If the return to DS is not working check the paths in Preferences>GoZ.
