Canvases produces always empty image
mikekmikek Posts: 195
Using a canvas produces always an empty image for me. My settings are the following:
I can add the whole scene to the node list but the result is always empty. When deactivating the canvas it renders fine. Is there something else necessary for it to work?
  • Cris PalominoCris Palomino Posts: 12,959
    You have a node, NL1, did you click the ellipses button to the right and select the object that it should render for that node?  http://prntscr.com/bxkrla
  • barbultbarbult Posts: 27,477
    I am not a Canvases expert, but here is a forum thread tutorial. And here is a thread about emissive surfaces in Iray canvases.
  • mikekmikek Posts: 195
    Thanks for the suggestions i found a solution. When testing the scene on my second PC who uses a older Daz Studio version it did work there without changing anything. I retried it on the first again and it was still black but after saving the project and reopening it works now.
    Well, that's good to hear.
