Voodoo bundle question about required products
Hi.  Looking at the Voodle Bundle - some of the products inside of it 'Require' Darius 6 and Monique 6 - but wanted to know if those would basically work with Genesis Male 2 and Female 2 OR if they're not going to be of much use without the specifically identified figures (Darius/Monique).  hoping for quick feedback so can decide before sale is off.
And any ideas how well this should work with Carrara.
Thanks.
  • barbultbarbult Posts: 27,499
    Can you give a link to the specific bundle you are asking about? I see nothing in the store search with "Voodle". I see several with "Voodoo", but none of the ones I found require Darius or Monique.
  • Sorry - meant Voodoo Magic Bundle - if you click on individual products inside of that, some require Darius 6 or Monique 6 - and wanted to know exactly how 'required' those really were.  Links below - thanks
    http://www.daz3d.com/voodoo-magic-bundle
    http://www.daz3d.com/doctor-shadow-for-darius-6 ;
    Dr. Shadow uses the base G2M UV, so you can put the skin on any Genesis 2 Male; you don't need Darius 6 to use the skin. The custom morphs may look different on other Genesis 2 Males, if you don't have Darius 6, but you can use them and see if you like the result.
    FWSI Marie HD for Monique 6 is a similar situation. The skin uses the Genesis 2 Female Base UV Maps, so you can use it on any Genesis 2 Female character. The morphs can be used on any Genesis 2 Female, but they may look different than the creator intended, if you don't have Monique 6.
    So the bottom line is, you can use the products without the "required" Darius and Monique. Shapes may or may not be pleasing without them, but skin should be fine.
    I'm back again. I just loaded Dr. Shadow. He only uses Darius 6 Body at half strength and doesn't use Darius 6 head at all, so you should get exactly the same head shape whether you have Darious 6 or not.
    FWSA Marie uses 75% of Monique 6 body and head, so she will differ more from the artists intent without Monique. She still looks OK, but a little less ethnic.
  • Thanks so much for checking that and getting back with a reply so quickly.  Will wade back into that sale and look for interesting things to pick up with that in mind.
