Veins
I am having a problem trying to apply the Phillip Vascularity On material to my figure. It is listed in the Smart Content tab, but it just won't load. All the other materials listed in the Smart Content tab work perfectly.
  • Richard HaseltineRichard Haseltine Posts: 112,067
    Have you tried rendering or are you looking at the preview? Iray or 3Delight?
  • kaotkblisskaotkbliss Posts: 2,918
    It may be one of those products where you need to select the figure, then go into the surfaces tab and select the parts of the body you want to apply the material to. Sometimes they work with just selecting the figure, sometimes you need to select the figure and the material zone.
  • Richard
    I have tried rendering the image using both Iray and 3Delight. Neither worked.
    kaotkbliss
    I tried selecting both the object and the surface at the same time. Nothing happened.
