G3F skin with dark nipples
Don't ask why ;-) but I'm looking for a G3F skin with dark nipples. So far I got Kelly (a little too pale), Lilinoe (nipples not dark enough) and Enya (skin to reddish) and was disappointed that the nipples of Sapphie and Dewi weren't dark.
Any  suggestions? Thank you.
  • nicsttnicstt Posts: 11,715
    I'd suggest darkening them yourself.
    if there is a SSS map take it into gimp photoshop. Or what is in the translucency colour or transmitted colour.
    a simpler method would be to use a layer above, and use either black, or the colour you're after, then either use a mix method that best works for what you require, or turn the opacity down. then save the new texture as a custom one.
    You could also try using the LIE editor.
    ... And seriously, send me a PM as to why. cheeky Curiosity is now officially killin' me.
    I could post how, but the images would get deleted which wouldn't be helpful. :)
    Try Priya http://www.daz3d.com/priya-for-genesis-3-female-s
    This is one of the problems with not having nude promos, inability to see ALL of the product
    Have you seen "Carly for G3F" by SecondCircle over at rendo? Dark skin character, with the skin in three different variations of darkness. There are no nude promos there, but I do have one at my DA gallery of the skin on  a different body morph. I can't link it due to the nudity, but my gallery is under the name "jakiblue" and hte image in question is called Natasha. Carly does have dark nipples.
  • ANGELREAPER1972ANGELREAPER1972 Posts: 4,829
    unless his character isn't dark skinned there are a lot of nipple colour variations for the fairer skinned probably best bet is doing after render or if you can wait if this is for a genesis 3 female wait for zev0's upcoming skinbuilder 3 the genesis 2 version of skinbuilder pro allowed you not only create your own skin colour, makeup, eye,  but nipple colour and even pubic hair colour had few different pubic hair styles too
    Ahhh. I just re-read OP's request again....I didn't realize he wasn't specifying a dark skin. My apologies.
  • 3Diva3Diva Posts: 12,058
    It would be super fast and easy for you to do it yourself if you have gimp or photoshop or any other art program. I did a quick mini-tutorial (it's for adding eyeliner but you can follow the same steps on the torso to darken the nipples): http://www.daz3d.com/forums/discussion/comment/1392701/#Comment_1392701
  • 31415926543141592654 Posts: 975
    Amandla for Josie is dark, but also small if that makes a difference.
    edited July 2016
    http://www.daz3d.com/fwsa-halina-hd-for-kalea-7
    just going through my bought stuff this lady has darkish nipples and she's on special  at $6.95 right now made for Kalea 7 but should work well on other g3f yep just tried her skin on base g3f from starter essentials works well
    FWSA Halina HD for Kalea 7 in Vendor, Sabby,  3D Models by Daz 3D
    Post edited by Chohole on
    edited July 2016
    FWSA Paloma HD for Victoria 7
    edited July 2016
    she's more average caucasion skin but has brownish nipples bit smaller than others
    really like this skin very pretty but also good as a tough girl with right expression used her as a vamp recently
    http://www.daz3d.com/mrl-eden-32657
    edited July 2016
    with this one not really dark but kinda light brownish but not pink or pale skinish
    http://www.daz3d.com/mrl-willow
  • alienareaalienarea Posts: 547
    A lot of suggestions, thank you
  • sura_tcsura_tc Posts: 174
    Darkening nipples should take no more than 5 minutes with Photoshop or GIMP. Take its texture select the area you want to darken. Make it a layer and darken it.
    edited July 2016
    I went through my collection of Generation 7 characters, the darkest are:
    Kalea
    Hahana for Kalea
    Kensey for Genesis
    Lynsey for Genesis
    Camile for Bethany (not as dark as the others)
    If skin color does not matter, I think Hahana has the darkest in my collection.
    Post edited by 3141592654 on
  • jardinejardine Posts: 1,223
    a fair number of adam thwaite's genesis 3 characters do, i'd say.
    as a plus:  you can preview his character's skins pretty completely on his site.
    j
