Uninstalling via Smart Content...does it remove everything?
jakibluejakiblue Posts: 7,281
If I uninstall the Genesis 3 Essentials via Smart Content/Connect, does it actually uninstall EVERYTHING and remove all traces of it?
I'm having some problem with some G3F characters deforming upon posing, so I was going to uninstall my G3F and all my G3F characters, and then reinstall them, but I wanted to make sure that uninstall would remove all traces of them from my comp so I can try and narrow down exactly why she is deforming so badly.
  • nightwolf1982nightwolf1982 Posts: 1,320
    No, the uninstall option only removes the Smart Content/Connect links.  You'll have to manually delete the folder containing the Genesis 3 Essentials.  This most likely won't fix the problem, though.
    The way to fix it is to either delete and reload the character, or go to Edit > Figure > Rigging > Adjust Rigging to Shape.
  • DAZ_RawbDAZ_Rawb Posts: 817
    Uninstalling through smart content will remove all of the files from any connect installed product. If you have also installed the product through DIM or manually you will need to uninstall those as well.
    Link files that you created for connect installed products will remain even if you uninstall and will prompt you to install that content again if you try and load those link files through content library.
    It certainly removed the product I returned yesterday & uninstalled.
