Morph dials for Victoria 1, 2 clothing ?
KGKG Posts: 0
Hi
I purchased a couple of items that are compatible with Victoria 1 and 2, for example Victoria changing eyeware
There suppose to be a dial to change the type of frames, but there's any related Dial in the parameters Tab
I checked that the glasses are selected in the Scene tab, I tried to move other parameters to see if the Dials appear ( I read something like that on the forums)
I didn't fit the glasses into genesis, so they are in the original state, not conveted to triax
Is there a trick to see the sliders/morphs for old version? or they don't work at all?
Thank you
  • Richard HaseltineRichard Haseltine Posts: 112,089
    What application are you using, and what version? Geoemtry-changing has been problematic in DS4, though it's more-or-less working in 4.5.
  • KGKG Posts: 0
    Hi Richard
    Im using DAZ Studio Pro 4.5 , I updated it and after that I installed the product
    If the product is for M4 or V4 I can see the Morphs in the parameters TAB, but not for Victoria 1 and 2 products ( haven't tried V3 and M3)
    Do you have links to the products in question?
  • KeryaKerya Posts: 10,943
    edited October 2012
    The changing eyewear is here:
    http://www.daz3d.com/shop/victoria-s-changing-eyewear
    Edited to add:
    Same body part swapping code as Victoria's Changing Fantasy Suits and Victoria's Changing Ponytail. Just select the frames and turn the dial and a new style of eyewear appears. Then you can pose them, Scale them, Move them!
    Sounds like geometry switching ...
    Post edited by Kerya on
  • KGKG Posts: 0
    Here is the other
    http://www.daz3d.com/shop/victoria-s-changing-ponytail-collection
    Basically the same problem with both
    With the ponytail at least, it's sort of working. There isn't a slider, but there is a pop-up list button labelled CHANGE_PONY or CHANGE_BANG between Point at and bend in the general parameters group - clicking that will get you a list of alternative parts, but they are untextured and lack the morphs they should have (you can fix the former in the surfaces pane by copying from the Preview surface and pasting to the Default surface). I don't have the eyewear to see if that's the same. It's certainly worth a bug report though.
  • fixmypcmikefixmypcmike Posts: 19,743
    I've bug reported the VCPC problem: https://bugs.daz3d.com/view.php?id=48228
  • KGKG Posts: 0
    Thank you all for your support
    I verified the Victoria changing eyeware works using the dropdown list where Richard indicated, its only the VCPC that doesn't load the textrures
  • KibbyKibby Posts: 60
    Have they corrected that morph dial for the Victoria's eyewear yet? I bought it for Genesis and is stuck with its default frame. I'm looking forward to try different fashion.
    Have you tried it in the latest build (4.5.1.56)? The bug report is marked as resolved.
  • KGKG Posts: 0
    Hi KibbyCabbit
    I was able to change them using the work around Richard shared in this thread
    Can you walk me thru? I'm trying to find the drop-down menu somewhere on user interface -- with no luck. Does it need the ponytail content installed for that to work?
    Thanks!
  • KGKG Posts: 0
    Thanks!
    Sure
    Once you get the EyeWare loaded, go to Scene tab, expand the Changing Eyewear -br/ eyewear
    Select the eyewear bone
    Then go to the parameters tab , select All
    You will see xTrans, yTrans .... etc... at the very bottom there is a dropdown list named Change Frame
    Select from the dropdown and the eyewear model will change
    It doesn't need ponytail
