Multipe versions of Vicki in the library
So some of my Vickis have (multiple) versions like this. How do you fix this?
DAZ4.9 always updated with new versions.
409 x 247 - 20K
  • ColemanRughColemanRugh Posts: 511
    Because when you morph them it does it to the multiple of the parenthesis
  • Richard HaseltineRichard Haseltine Posts: 111,348
    Which figure is this? In the Parameters pane option menu (the lined button in the top corner, or right-click the tab), uncheck Cosolidate Properties - each morph will then be listed individually and you can open its Parameter Settings (by clicking the gear icon on the slider) and chaneg the label to make it unique - though commercial sets should not be doubling up labels.
    Thanks a lot, Richard!
    That is my genesis 2 female. But I get this on several Genesis people. Thanks for your advice. I'll give that a try.
    I contacted DAZ and they said I probably have the same morphs in multiple sub-libraries. I'll try both of your suggestions when I get home. Thanks!
    It shouldn't be the same morph - that would throw errors - it's different moprhs with the same label - which is allowed by DS.
    Your advice with the parameters option menu helped. Thanks a lot!
    I didn't mess with the library directories. I need to research that more.
