Animated Shapes Separate Morphs
RCDescheneRCDeschene Posts: 2,817
edited July 2016 in The Commons
Has anyone ever complained about the lack of separate head and body morphs for the characters in the Animated Shapes for Genesis 2 Male(s) product before?
Post edited by RCDeschene on
  • RuphussRuphuss Posts: 2,631
    i would complain there is nothing animated in it
  • RCDescheneRCDeschene Posts: 2,817
    I think the implication is that they're cartoon characters, particularly a very '97 - '06 DC style. :)
    So I sent in a support ticket and they told me to take it up with the artist directly. So, does anyone know The Six's member page?
    Whenever there has been complaints about the lack of the separate head and body morphs the explanation is often that the shapes are so radical that the neck would not flow smoothly if done separately.
  • wolf359wolf359 Posts: 3,955
    And in this package of highly stylized Characters, this is exactly the case.
    edited July 2016
    So? Dosen't stop the major stylized icons like Girl, Aiko, and Hiro, which have been able to do that since Gen 4. Even 3D Universe's Genesis characters had separate morphs. Also, that's why most character artists bring the neck along in the head morph process, to make the transition between styles smoother.
    Either way, I still would like to try and get in-touch with the artist and at least pitch the suggestion. But the problem is, with this new forum layout I can't get access to the Members list.
  • RobotHeadArtRobotHeadArt Posts: 917
    You could use the Clear Selected Deltas from Favorites to manually dial out the head or body separately.  There's a tutorial on how to do it here.
  • LeatherGryphonLeatherGryphon Posts: 12,461
    edited July 2016
    I've been disappointed several times by creatures that did not have separate morphs for the head.  Then I stopped buying from those artists.
    Okay, so I was able to get the weight map preset that was featured in the tutorial from the author directly as you'll see in the comments. However, when I was going about the process for separate head/body morphs I got some errors...
    1600 x 852 - 257K
    1600 x 900 - 266K
  • JackFosterJackFoster Posts: 143
    I'm assuming you exported the morphed figure to use for re-importing the morph. When you did so, did you remember to turn the figure's resolution to base?
    Yep! I knew I forgot something! Also, after a few scale reworkings, I was able to get it to exactly as I weanted it! Thanks guys! :D
    Okay, one more question... So, I was able to get the separate head/body weight mapping process to work alright, and I even went ahead and adjusted the scale of the morph to of the base shape before .obj exporting so the head and body flow together (otherwise resulting in a funky neck stretch/crunch with the separate morphs applied). Now my last dilemma is trying to get hair and clothing to do the same...
    1154 x 725 - 254K
