DSON (64 bit version) won't download from DIM
It wants versions of Poser I don't have. I have 64 bit Windows 7 and Poser 10, not Poser Pro anything. Should I try 32 bit DSON?
This is all from needing to re-install and reconfigure everything after a hard drive crash, which seems to be beyond me. Things are slowly shaping up.
534 x 558 - 34K
    You may be better off asking this question in the Poser forum.  To change the forum  click to edit your first post and then select Poser Discussion forum from the drop down list at the top, left of the page.
  • LeanaLeana Posts: 13,639
    You need to install the "bit version" of DSON importer corresponding to your Poser version, not to your OS, and Poser 10 is 32 bits only. So yes you will need to install the 32 bits version of DSON importer.
  • Thank you! It took me awhile finding 32 bit DSON, but installed perfectly the first time! No painful hand configuring as before. That means I also have Install Manager fixed I guess.
    I'll remember about using the Poser forum. I wondered about that. I'm a bit rattled after the hard drive crash.
