OUT OF MEMORY?
Gentle_dragonGentle_dragon Posts: 14
Got the message OUT OF MEMORY while importing an FBX character from daz3d through the 3dxchange 6 pipline. My rig has 64GB ram, 8-i7GPU's, a GForce 780 video card and 2-2TB harddrives, what is the problem and how can I fix it?
Post edited by Gentle_dragon on
  • barbultbarbult Posts: 27,655
    I'm not familiar with the 3dxchange 6 pipeline, so I can't help you there, but I think your stated specs have a typo: "8-i7GPU's". Do you mean that you have an I7 CPU with 8 cores? The GPU would be your video card.
    If you don't receive a helpful reply here, try submitting a help request to Daz Customer Support. https://helpdaz.zendesk.com/hc/en-us/requests/new
  • FishtalesFishtales Posts: 6,244
    I'm not sure but it could be there isn't a segment of continuous ram for the transfer. I seem to recall that even the ram can get fragmented and cleaning it might help.
  • SixDsSixDs Posts: 2,384
    Is not 3DXchange a 32-bit application? If so, you can add memory to your system until the cows come home, but it won't have an effect. I understand that there is a patch available that will max the memory access for it, but that still limits you to somewhere south of 4 GB.
  • KeryaKerya Posts: 10,943
    Largeadressaware https://www.techpowerup.com/forums/threads/large-address-aware.112556/
    Thanks, Kerya. I have used it with Bryce and Hexagon but forgot that it was kind of one utility to rule them all for 32-bit apps.
