How do you access Mimic Live? I bought it installed and i can't see it anywhere
SO, where is it? how do you access it? it's not in the Panes with the other tools. Strange. It says it's installed as a plugin but it's gray color even though it has my registration code. But it tells me it must be registered
  • nokoteb99nokoteb99 Posts: 943
    HOw do you register a plugin, i don't understand. Cause it's not just Mimic i have another plug that also says  "it needs to be registered" and it's grayed out
  • Richard HaseltineRichard Haseltine Posts: 111,380
    Have you entered the correct serial number from your Serial Number page? https://www.daz3d.com/downloader/customer/serialnumbers The grey box shoudl give the the first few characters (which are the same for every code) to help you double-check you are using the right one. Have you then restarted Daz Studio?
    Yes I entered the correct serial number
