Any easy way to convert INJ pose Head files to Dial type faces?
I need to Save a morph of my character which different faces and some of the ones i want are not anywhere in the tree of stuff to choose. And i'm pretty sure it's because those faces are like old Poser INJ files. They are not dials. Specifically I'm talking about  The product in daz   12 Faces for Genesis 2 Female. and  Fab Faces for Genesis 2 female. Might be the same with the fab faces for g2 male version.
All the other face/head morphs i've bought were under dials so when i make my morph i can export them with my full body morph.
  • Richard HaseltineRichard Haseltine Posts: 111,371
    An INJ pose stillc rated a dial (or dials) - it injected (hence the name) morph deltas into an existing channel, renamed it and displayed it. The presets for G2F may be labelled as INJ poses but they aren't. They will be presets for oen or more existing morphs - check the Currently Used group in the Parameters pane. What is that you are wanting to do - exporting as OBJ and reimporting as a new morph is probelematic, especially with expressions, as you lose any correction morphs thata re applied dynamically (and of course you can't share the results with others, unless you are using a merchant resource pack in accordance with its terms).
  • nokoteb99nokoteb99 Posts: 943
    I want to Make an   Save As/Suportted/Morph Asset    that not only contains body shape morph but also facial.   And i know i can do it cause i'm doing many trials like with faces that have dials. But the faces that don't have dials do not appear in the MorphAsset dialog box anywhere to select. And PS. I want to export to use in unity. And yes i have a way to do it easily. i have a product called megadz.
    Some expressions wil be a single parameter, some will be a preset thata pplies a selection of parameters. But they must use parameters of soem kind - there's no other way for them to work (well, I suppose they could be DForms - but I'm not aware of any that are). Check that they are not using the parameters on the head rather than those on the figure.
