• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • pwToon Help
    pwToon is a Shader. The proper way to apply a shader is to Select the Figure in the Scene Tab, then in the Surfaces tab select all the surface areas to apply the shader to. Then with All of that still selected Double click on the pwToon preset like Cartoon Classic. Then Render when finished.
    Also Shaders only funtion properly in the 3DeLight render setting.
    By
    Jaderail Jaderail December 2013 in New Users
  • pwToon Help
    I've been using Poser for a couple years now. I'm completely new to Daz Studio and I've just bought pwToon. I'm completely clueless on how to use pwToon with Daz Studio 4.6. I managed to find the pwToon Resources in the Content Library and I see Airbrushed Red, Cartoon Classic, Clean Drawing, etc...
    When I click on a figure/character in the Perspective View (middle screen) and then in the Surfaces tab, I randomly click on a Material. Then I go and double-click on Cartoon Classic (for example). Nothing happens (even after rendering the image), I don't see a toon render or the words: Shader: pwToon anywhere on the Surfaces tab.
    Can someone enlighten me or provide newbie steps (maybe with pictures using Daz Studio 4.6) that I can follow along to get this to work?
    By
    sxiong1111_f1bfa677c8 sxiong1111_f1bfa677c8 December 2013 in New Users
  • Fix black area in Cartoon 3Delight render?
    jestmart said:
    This is a known flaw, surfaces that are close to parallel to the camera view will appear black. There are a number of toon shaders that gives better control and results than the built toon render.
    Ah ok. I guess I'll look at the other shaders. I kind of liked the default one but I already have PWToon.
    Thank you very much!
    By
    ChromaDrake ChromaDrake December 2013 in New Users
  • Applying built-in Daz 4 Toon shader to single objects
    Richard Haseltine said:
    The toon mode will have no effect on surfaces that use pwToon (or any shader other than DAZ Default Shader). What the option does is tell DS to use alternative code on surfaces using the DAZ Default Shader.
    Ah, ok! Thanks for the info.
    By
    ChromaDrake ChromaDrake November 2013 in New Users
    By
    Richard Haseltine Richard Haseltine November 2013 in New Users
    Is there a way to apply the cartoon shader build into DAZ 4 to a specific object in a scene, rather than the whole scene? I would like to combine it with PWToon using PWtoon for some objects and the cartoon shader for others.
    Any help would be great! Thanks!
    By
  • Rough outlines with Crescent’s pwToon shaders
    Hi – I have found that the outlines created by Crescent’s pwToon shaders are relatively rough or pixilated looking. I’m rendering at high resolution but that doesn’t seem to change anything.
    Just wondering if this is an inherent quality of Crescent’s shaders or something I’m doing? I’d prefer smoother outlines if possible.
    Thank you for any help on this.
    roberto
    BTW - The outlines around the hand are the most obvious.
    By
    info_6b436693f7 info_6b436693f7 November 2013 in Daz Studio Discussion
  • 3Delight Surface and Lighting Thread
    Not really close, yet, but at least it is sort of heading in the right direction with pwToon.
    Edit: Added one more try before sleepy time :) The last try is actually the top one.
    By
    Renpatsu Renpatsu October 2013 in The Commons
    Don't think I got any good Noir presets for pwToon, should be doable, but I would have to dabble with it. I got quite decent Cel Shaders for pwToon (Crescent's presets). The only good Sin City style presets I got are for the Visual Style shaders.
    By
    Mustakettu85 said:
    Takeo.Kensei said:
    If you don't want to deal with surface group then render in Point Cloud mode. It's quicker, and saves from the ID Group messing problem.
    Soooo... so that script does enable point cloud for everything we throw at it? Or are you talking about writing pointcloud scripts of our own?
    Yes the DS Scripted render Pointcloud mode does the job. Just disable the Occlusion light if you don't want an additional light in your render
    Taken from 3delight Manual :
    There is no more subsurface groups: groups are implicitly declared by the geometry rendered
    and baked in the point-cloud file.
    As for my shaders, I didn't do anything since a few month. Too much work and was too tired most of the time or busy with other things. But I'm a nice guy I took the cissors and did the job and made a sort of panorama (Thanks to XnView which was very handy there)
    If you want a look at something see here and here. It's too big to post in the forum. There are various tests and got some cool accidents sometimes
    I add two renders here. The first one is one I cropped the head. Why? because with my unrealistic head morph it can distract from judging the shader. That's what I thought when I looked at it earlier. Because when I rendered it, at that time I thought it was not good. But seeing it today I think it's not so bad.
    Second one is some playing with NPR shading with Sin City cartoon comic in mind. Question for people having PWtoon : can you achieve this type of render easily?
    By
    Takeo.Kensei Takeo.Kensei October 2013 in The Commons
  • pwToon and front view
    When i render in "perspective view", i get good results. But when i choose "front view", something messes up - i'm getting mostly black figure instead of lighted/shadowed. I 'm on daz 4.6 and i use "technical drawing" preset
    example:
    By
    akmerlow akmerlow October 2013 in Technical Help (nuts n bolts)
  • DAZ Studio Pro 4.6.1.17 General Release, Now Available!
    wsterdan said:
    wsterdan said:
    DAZ_cjones said:
    wsterdan said:
    It looks like my pwToon shaders no longer work; I can't apply them, nor do models saved with the shaders render correctly (models' colours render super flat, textures blank).
    I'm on a Mac; can anyone confirm?
    Thanks,
    Walt Sterdan
    I just applied and used it. pwToon has files that installs into the Studio folder. You may need to reinstall the pwToon product.
    Thanks, knowing that it should work is all I need. I'll track my problem down.
    Thanks for the quick response, it's very much appreciated.
    -- Walt Sterdan
    Tracked it down.
    DIM has decided to add an extra "DAZ 3D" folder into the install paths; very, very irritating.
    Below, the first snapshot shows the path I set for a fresh DAZ install to test where it's going; the second shows the path settings after the install.
    This is the first problem I've had with DIM since it came out. Any suggestions that will fix the issue of the extra level of "DAZ 3D" welcome.
    -- Walt Sterdan
    Can you post the top of the Settings > Installation tab, that shows where 32-bit and 64-bit software installs?
    By
    fixmypcmike fixmypcmike October 2013 in Daz Studio Discussion
    wsterdan said:
    Thanks,
    Walt Sterdan
    -- Walt Sterdan
    Tracked it down.
    -- Walt Sterdan
    By
    wsterdan wsterdan October 2013 in Daz Studio Discussion
    Thanks,
    Walt Sterdan
    -- Walt Sterdan
    By
    Thanks,
    Walt Sterdan
    By
    DAZ_cjones DAZ_cjones October 2013 in Daz Studio Discussion
    Thanks,
    Walt Sterdan
    By
  • pwToon not showing in Surfaces Tab DS 4.6 Pro
    Issue resolved by Re-installing DS Pro 4.6 using DIM.
    Seems I may have messed things up when I moved/merged everything from to
    some time ago after the initial install. Forgot about that.
    One thing though, is that pwToon doesn't seem to be compatible with DS Pro 4.6 64bit ?
    Anyhow, Thank you again for the assistance.
    By
    info_6b436693f7 info_6b436693f7 September 2013 in The Commons
    OK. Thanks. That's helpful. At least I know I'm doing things correctly. I might try a fresh install of DS 4.6 and pwToon and see what happens. I'll post back with results. Probably tomorrow.
    By
    There is something wrong with your shaders.
    I just tried this. I loaded Genesis, added UberSurface Base from Shader Presets > omnifreaker > UberSurface I then selected Genesis again in the Scene tab, and in the Surfaces tab, and applied pwToon from Shaders > pwToon_DS4 > pwToon Resources > Airbrushed Red.DS, and it works perfectly well.
    You may need to update your shaders to get the latest versions?
    The name in the Surfaces pane changes to Shader: pwToon for all selected surfaces. I am using Win 7, DS 4.6.0.15
    By
    JimmyC_2009 JimmyC_2009 September 2013 in The Commons
    Thanks for replying.
    Yes, I just tried selecting just the G2 face. But once again no pwToon in shader tab. Just the original shader which is omUberSurface.
    The non pwToon default DS shader presets all work fine with multiple objects.
    Something I've noticed is that if I use a pwToon shader such as Airbrush Red, the selected object surface changes to red but the shader tab keeps showing omUberSurface. The diffuse color setting in the adjustments panel on the right changes to red as well.
    By
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
