• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
Daz 3D Forums > Search
  • Leg holster identification
    You might be able to use the geometry editor to hide the parts you don't want.
    I've not used it at all really, but there is a thread here that gives a bit of a start on how to use it here: https://www.daz3d.com/forums/discussion/146436/geometry-editor-tool-tutorial-anywhere? I'd select the facets I didn't want on the other side and apply a  new surface to them, then make that surface transparent/hidden. That way the facets would still be there to correct any errors if I managed to select the wrong ones and needed to restore them to the main model.
    Have to confess the main reason I've not used geometry editor much is because in these situations I export an obj model, edit it to delete unwanted facets in a modeller and then re-import and convert to a piece of clothing again. The way to do this is to:
    1. Zero the figure and harness.
    2. Unparent the harness from the figure.
    3. Make sure the harness is at base resolution.
    4. Ensure that the haness root X, Y and Z translations & rotations are zero.
    5. Hide everything in the scene except the harness.
    6. Export the Harness at 100% scale as an obj file using menu option File| Export.
    7. Edit the harness obj file in a modeller.
    8. Save the modified harness as an obj file from the modeller at 100% scale.
    9. In DS import the modified harness model at 100% using menu option File| Import
    10. Use menu option Edit| Object | Convert to Figure and select 'General Weight Mapped' rigging when the popup dialogue box appears.
    11. The new harness will now have a scene tree name of 'Figure: <obj filename>'. Change the name in the scene tree now if you want.
    12. Then use the transfer utility to copy across the original harness rigging to the modified harness. The way to do this is use menu option Edit| Figure| Transfer Utility . Here you select the old harness as the source figure, the new harness as the destination figure and set it running.
    13. Copy materials from the old harness to the new one.
    14. Now your altered harness is ready to use.
    Sounds long winded, and it is, but then you'll have your own unique harness which can be saved as a library part or simply fitted to your character.
    Regards,
    Richard
    By
    richardandtracy richardandtracy June 2025 in The Commons
  • [Released] Bone Minion Batch Converter for Genesis 8 Poses [Commercial]
    RiverSoft Art said:
    Pax Asteriae said:
    It's a nice product, when I can get it to work. But it thinks probably a solid 80% of my pose collection for G8M aren't actually poses.
    09:03:23 GMT+0100 (GMT Daylight Time):    SKIPPING unknown "preset_pose" file: E:/3D Runtimes/My DAZ 3D Library/People/Genesis 8 Male/Poses/Adama Poses for M8/Adama Pose 01.duf
    09:03:23 GMT+0100 (GMT Daylight Time):    SKIPPING unknown "preset_pose" file: E:/3D Runtimes/My DAZ 3D Library/People/Genesis 8 Male/Poses/Adama Poses for M8/Adama Pose 02.duf
    09:03:23 GMT+0100 (GMT Daylight Time):    SKIPPING unknown "preset_pose" file: E:/3D Runtimes/My DAZ 3D Library/People/Genesis 8 Male/Poses/Adama Poses for M8/Adama Pose 03.duf
    09:03:45 GMT+0100 (GMT Daylight Time):    SKIPPING unknown "preset_pose" file: E:/3D Runtimes/My DAZ 3D Library/People/Genesis 8 Male/Poses/Aerial Combat Poses/Aerial Combat G8M 01.duf
    09:03:45 GMT+0100 (GMT Daylight Time):    SKIPPING unknown "preset_pose" file: E:/3D Runtimes/My DAZ 3D Library/People/Genesis 8 Male/Poses/Aerial Combat Poses/Aerial Combat G8M 02.duf
    09:03:45 GMT+0100 (GMT Daylight Time):    SKIPPING unknown "preset_pose" file: E:/3D Runtimes/My DAZ 3D Library/People/Genesis 8 Male/Poses/Aerial Combat Poses/Aerial Combat G8M 03.duf
    09:17:34 GMT+0100 (GMT Daylight Time):    SKIPPING unknown "preset_pose" file: E:/3D Runtimes/My DAZ 3D Library/People/Genesis 8 Male/Poses/Anniekicks/Kyokushin Karate/Kata/KK Back Stance Double Knife Hand Block Left.duf
    09:17:34 GMT+0100 (GMT Daylight Time):    SKIPPING unknown "preset_pose" file: E:/3D Runtimes/My DAZ 3D Library/People/Genesis 8 Male/Poses/Anniekicks/Kyokushin Karate/Kata/KK Back Stance Double Knife Hand Block Right.duf
    09:17:34 GMT+0100 (GMT Daylight Time):    SKIPPING unknown "preset_pose" file: E:/3D Runtimes/My DAZ 3D Library/People/Genesis 8 Male/Poses/Anniekicks/Kyokushin Karate/Kata/KK Bow Pose 1.duf
    And so on and so forth.
    Is there a way I can convince it to recognise all these poses too, or am I doomed to failure?
    Your Daz database must not be reporting the metadata for files. I tried to write a fallback where the script is looking inside the files and use that, but it looks like there is a bug. I will work on that.
    In the meantime, uncheck "Check Content Type When Adding Files" will allow you to add any file
    I just tried it and it didn't work... so I took a closer look at the hover text and it doesn't include adding by directory. *facepalm* So I guess I have a very long and boring conversion journey ahead...
    EDIT: Strangely though, doing it this way seems to make it convert the poses much faster, which is weird but nice.
    By
    Pax Asteriae Pax Asteriae June 2025 in Daz PA Commercial Products
    By
    RiverSoft Art RiverSoft Art June 2025 in Daz PA Commercial Products
    ChainedStar said:
    RiverSoft Art said:
    Charlie Judge said:
    Assuming we have the apprpriate Bone Minion converter does it work with poses other than G8 & G8.1?  For example Genesis 3 poses for Genesis 9 ?
    No, it is only for batch converting G8 poses. Hopefully, I will make a Bone Minion Batch Converter for G3 Poses in the future.
    It looks like a great product but I am a bit disappointed there is no discount for those of us who already own the included Bone Minion for Genesis 8 and 8.1 Poses for Genesis 9.
    I am sorry, that was an oversight on my part. Originally, the product did not include any of the BM products. Bone Minion for Genesis 8 and 8.1 Poses for Genesis 9 was added at the last minute.
    Hello, thanks for such a great tool, I have a few questions:
    1) Do you plan to do the same for Genesis 2?
    Eventually yes
    2) What does the conversion speed depend on for this product and in your previous "single" products? Does it depend on the CPU performance or is it just the ancient DAZ3D engine that imposes limitations and even with i9/Threadripper it will take minutes/hours for really big pose collections?
    Conversion would be CPU bound. The biggest limitation is having LOTS of Daz content though that has clogged up the Daz metadata database (you can try unchecked "Metadata" in the options, it might help).
    3) Do you have any plans to create/expand your scripts for converting animations (one pose with several keyframes inside)?
    I hadn't thought about that. I will have to think about how to do it. Thanks for the suggestion.
    By
  • Cant see DAZ content in Smart Content
    Richard Haseltine said:
    Does the content have metadata (e.g. do you see the file-type tags, such as Actor or Material, at top-right of the thumbnails)?
    Thanks for the help but after reinstalling Daz, the issue is gone. Probably i might've done something wrong during installation.
    By
    MelonLord MelonLord June 2025 in Technical Help (nuts n bolts)
  • Mesh deformation when using geografts
    Hello everyone,
    I have been breaking my head over this problem for days now and it's driving me up the wall. I have Victoria 9 in Daz, with the Golden Palace and STX geografts applied. I am then importing the Daz file into Blender using Diffeomorphic.
    In Diffeomorphic, I'm importing base JCMs, as well as additional JCMs for the Golden Palace. After I'm done further cleaning up the object I using Diffeomorphic again to merge the geografts. I then load a Golden Palace pose preset (Pose 03 in this case, with the figure lying on the back with their legs held up). Everything looks good so far in Blender. I then using the Better FBX exporter to export the base shape and animation to Unreal Engine.
    In Unreal Engine, I import the FBX file, and end up with a bunch of materials, a skeletal mesh and a skeleton of the figure in A-pose, and a single frame animation sequence that represents the pose preset I loaded. The base skeletal mesh and skeleton look completely correct in Unreal. However, when I look at the animation sequence where the character is lying on their back with their legs held up, the Golden Palace graft is sticking forward too much, looking very odd. If I take a look at the wireframe I can tell that this area is very stretched, whereas in Blender's wireframe, the geometry looks very smooth.
    Something is going wrong between Blender and Unreal, but I can't put my finger on it. There's a lot of things I already tried:
    • Baking shape keys
    • Manually posing the character instead of loading the preset
    • Different orders of operation when it comes to merging the geograft
    • Removing the "Graft" vertex group which is not mapped to any bone
    I am getting at my wit's end here. Does anybody know what could be wrong?
    By
    glwsihmsynnlprsbvd glwsihmsynnlprsbvd June 2025 in Unreal Discussion
  • dForce Archmage
    barbult said:
    I don't own that hair, but does it perhaps have unused vertices? Is the export set to remove unused vertices, making the import geometry not match?
    Thank you. That seems to be where the problem lies: when you select this hair with the Geometry Editor Tool, DAZ shows in the Tool Settings Pane that it contains two Face Groups (default and head), and each of them contains 0 vertices. As a result, “Select All Vertices” doesn’t select anything — as if the hair isn’t a mesh object at all.
    At the same time, the Info tab shows that it contains 404,736 vertices:
    Name :
    BeachStyleLongHair_404736
    Label :
    Beach Style Long Hair Strands
    Class :
    DzFigure
    Vertices :
    404,736 / 404,736
    Triangles :
    0 / 0
    Quads :
    0 / 0
    Total Faces :
    0 / 0
    Total Lines :
    16,864 / 16,864
    Apparently, the reason is that the hair consists not of quads or triangles, but of lines.
    Honestly, I don’t really understand what kind of structure this is.
    Also, trying to “Edit Strand-Based Hair” doesn’t work either — this isn’t a Strand-Based Hair Node.
    By
    matew matew June 2025 in Daz PA Commercial Products
  • How do you create the files are in the Support folder?
    The DSON Cache does not store the product details, they are metadata in the database http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/tech_articles/metadata/start
    Where you launch the Edito metadata dialogue from is a matter of taste - for example, if you have 3Delight and iray (or Filament) materials and want to set their content type it can be easier to launch the dialogue from the specific sub-folder for those materials, then you can just seelct everything and assign it to the right type - otherwise you have to carefully go through the file list in the dialogue making sure you seelct all and only then ones to be given a specific type.
    By
    Richard Haseltine Richard Haseltine June 2025 in The Commons
    A good summary, but I would categorize after creating the Product. You can create a product from an entire folder structure, which will pull in everything in any sub-folders, but it does not have to all be under the same folder, just add another to the Product previously created (i.e., People/Genesis 8 Male/Poses/.., People/Genesis 8 Female/Poses/..). Edit the metadata from the Product view; all assets will be in one place, and you can do it all in one pass. Be sure to use Default categories, any other will create a new, read-only branch in the Categories tree. If you use Custom Categories (considered User Data), assign them after saving the metadata files (considered read-only Vendor Data). You can export User Data later as a back-up.
    By
    NorthOf45 NorthOf45 June 2025 in The Commons
  • dForce Archmage
    By
    barbult barbult June 2025 in Daz PA Commercial Products
    The process of creating the product metadata which the .dsa and .dsx file contain is as follows:
    Note: Steps 1, 2, 3, 4 and 5 are performed on the content library tab.
    Note: I am using a hypathical example of a set of poses in DAZ format. These steps will work with Poser directory format as well, just a different location in the Content Library Format lists.
    Step 1: Categorize all your poses. (You do that by clicking on the DAZ Studio Formats list and chase the directory until you are in the file folder where your poses live.)
    Step 2: Click right on the pose and select Create a Product from...
    Step 3: Identifiy in the pop up box what the product name will be.
    Step 4: Repeat Steps 2 and 3 for all you poses. You can select multiple poses and assign them all at once. You can add as many poses as you want.
    Step 5: Once you have included all the pose files into the product then click right on one of the files and choose Show Asset in -> Smart Content -> Products.
    Note: You should now be on the Smart Content tab. You may have to click on the Products tab to get DAZ to show the new product.
    Step 6: Select the new product and click right. Select Edit Metadata.....
    Note: At this point you now have a product created but it only lives in the DSON Cache files. The following steps will commit the information to hard drive by creating the .dsa and .dsx files.
    Step 7: The Product tab. Fill out the store, token, description, and Artists. Files and Scene IDs boxes need extra things from the assets tab and will be automaticly filled out.
    Step 8: The Assests tab. Top part identifies what you have identifed as being a part of the product. If your list is incomplete then perform steps 1 thru 5 on the missing bits.
        a: Select an item from the top part. Fill out the Type: box. (Midldle of the edit box) (You can do several items at a time by using the shift or control keys or the equivalent Mac keys). The top part of the edit box will start to fill in with X's as you proceed to fill in the lower part of the edit box. Filling in the Type box will have daz create the identifier, the little yellow box on the thumb nails for each of the pose files.
         b: Go thru the tabs at the bottom, (Tags, Descriptions, Compatibility Bases, Compatibilities, Userwords, User Notes) completing the tabs that you want to use. Filling in all of these tabs will create full function ability of Smart Content. So for your product of poses, when you select the Posing |Shaping tab and you have filled out the compatibility tabs, your scene will have the ability to identify your poses for the selected character in your scene. (Assuming you have Filter By Context checked.) (You don't need to fill in every tab if you don't want to but be aware that you will not have your product included in that functionality (Tags, Descriptions, Compatibility Bases, Compatibilities, Userwords, User Notes)).
         c: Repeat for all your pose files.
    Step 9: Select either Export or Accept (with Automatic Export box checked) buttons at the bottom of the Edit form. You should now have your dsa and dsx files.
    Step 10: Create the image that represents your pose package. Name it with the same name as the dsx and dsa files are using. Refresh your Smart Content tab. Size of image can be anything. I generate image sizes at 500x647. DAZ seems to like 114x148. Images in jpg or png format can be used.
    By
    DollyGirl DollyGirl June 2025 in The Commons
    By
    Richard Haseltine Richard Haseltine June 2025 in Technical Help (nuts n bolts)
    As NorthOf45 says, those files are the product metadata so you would need to create a product from the files (for a pose set you can essentially do that from a rght-click on the folder that holds the poses, though you iseally want the filte types and compatibility set too)
    By
  • Good CLOTHING simulation tutorial for Blender?
    Diffeomorphic does import the dforce pin maps for you and set the collision parameters. There's usually no need to scale 10x. If you want to do it yourself it may be useful to read the issue discussion, where some reference is also linked.
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Features/Simulation/Make dForce Simulation
    https://bitbucket.org/Diffeomorphic/import_daz/issues/410/better-dforce
    By
    Padone Padone June 2025 in Blender Discussion
    The Support Folder is for metadata, not assets. To make your own metadata (presumably for third-party products without any from Daz), you need to use the Content DB Editor. Much has been written about it elsewhere.
    By
  • Getting Currently Used Morphs
    This could probably be adapted to do that http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/metadata/list_products_used/start
    By
    Richard Haseltine Richard Haseltine June 2025 in Daz Script Developer Discussion
  • Material Application Issue in DAZ Studio 4.24 – Auto-Deselection?
    Here is a video from 4.24 with a product with metadata tags. Same problem. :(
    https://streamable.com/3srsn4
    By
    MargyThunderstorm MargyThunderstorm June 2025 in Technical Help (nuts n bolts)
    It is with every product and works totally fine in 4.22 without metadata tags.
    By
  • Let's appreciate/discuss today's new releases - more ongoinger thread
    Take your new stuff and multiply it by how many computers they need to be installed on and then the metadata tweeked to fit your needs! I am over 24,000 product files in DIM now and each computer has a different number installed. And on some I haven't even got to installing my non-DAZ store purchases and freebies on my newer computers.
    By
    memcneil70 memcneil70 June 2025 in The Commons
  • Can't Retarget Animations Assets to Genesis 9
    I imported the Genesis 9 character with the Import Facing Right checkbox unchecked in the DAZtoUnreal bridge.
    By
    superlativecg superlativecg June 2025 in Unreal Discussion
Previous Next
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
Create An Account
