G8/G8.1F Eyes - The E.T. Factor?
rlewisfr said:
Ok, thanks to the advice, I have put Rory in a corner to think about what she has done for a while, and now all of the ladies are showing their true, fine colours. I had to go in to the /data/.../morphs/ folder and remove references to the Rory morphs (as I do manual installs rather than auto from IM or Central), but after that it is great.
Again, can't tell you how much I appreciate it.
Ooh, now that I look at Rory's product page, I can definitely see where the extra features came from. I'm glad it was just that easy to take care of. I had at one point downloaded something from a Patreon and it overwrote the G8 core character, so even uninstalling everything from the character I bought didn't help - I also had to purge G8 Essentials. I learned to be a lot more discerning after that.
G8/G8.1F Eyes - The E.T. Factor?SapphireBlue said:
rlewisfr said:
SapphireBlue said:
@rlewisfr I think something else is going on here - those faces are not the proper faces of those G8/G8.1 characters. I think you might be in the unfortunate situation, where any G8 or G8.1 you load is loading in with an extra morph. It sometimes happens due to an error in a recent character purchase, where the character is dialed in with each other character you load.
In DS, select one of those G8/G8.1 characters you rendered before and check your parameters / shaping tab. Select the "Currently Used" option. Check through the list there to see if you've got some other character dialed in that the one you loaded. You may want to uninstall that other character for now to prevent this from happening. Others may have a better solution. Hope that helps!
EDIT: I'm going to hazard a guess that maybe you've got Dolly's head dialed in with those other characters. If I remember right, Dolly might have been a free gift for new members, and she has those features of big eyes, narrow chin etc. Just a guess!
Wow, thank you so much SapphireBlue, much appreciated. Yes, turns out there was some LY Rory Head morphs and a double on the RY Xara Head (Non HD) being added for some reason:
When I removed the offending morphs, things got WAY better and closer to the advertising material.
Is there any way to prevent this from happening to each G8/G8.1 load I do, or is this something I have to check each time I fire up a model?
Again, thank you so much for the assistance, I really do appreciate it!
I'm glad it helped!
So firstly, you need to put RY Xara's morph back in!! The 2 RY Xara morphs are 1 for her head shape and one for the HD details - they're not doubling up. The HD details add the finer details for close up renders. You can dial that down for distance renders etc, but the first one is her actual head shape. Without that, your render now is back to the basic G8 head shape only but with RY Xara's skin.
If you notice that LY Rory is dialed in everytime you start DS and load in G8/G8.1, then my only suggestion is to uninstall her for now and send a ticket to DAZ to see if there'll be an update for the character fixing that issue. Others here may know how to fix the issue in her files, but I don't have a clue about that I'm afraid. Right now, it seems LY Rory is the only problem here, so uninstalling her should prevent this from happening each time you load a G8/G8.1 character. So now I hope you can go back to appreciating their totally non ET faces like the rest of us do...
Limbstick ErrorDeleting won't help, you need to unisntall from the right-click menu. If you don't DS will keep looking for the deleted files and will give the error, even if you still have files from Install Manager/Daz Central.
Limbstick ErrorRichard Haseltine said:
lenplplpl said:
Oh, I have a similar problem.
I'm a new Daz user (Daz 4.21, MacBook Pro). I plan to model and animate characters in Daz and then export them to Blender for rendering.
I want to animate benchpress training. I imported the barbell, pinned hands with pins to stay in the same position, and attached IK chains to each hand and the barbell, but as probably more advanced users could guess, it didn't work out as expected (hands sliding etc.). I looked out for solutions and came across the LimbStick script, as it seems to be the perfect tool for such animations. I purchased it and tried to install it, but unfortunately, the error pops up whenever I try to run it ("An error occurred while reading the file, see the log file for more details").
2022-12-15 16:19:24.072 [INFO] :: Loading script: /Users/xxx/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_83712/scripts/3d universe/limb stick/3du limbstick g3+8.dse
2022-12-15 16:19:24.108 [WARNING] :: /src/pluginsource/DzCustomizeDlg/dsaddonwidgets.cpp(1024): File: data/3D Universe/LimbStick/3duLS.ui does not exist
2022-12-15 16:19:24.112 [WARNING] :: Script Error: Line 149
2022-12-15 16:19:24.112 [WARNING] :: TypeError: Result of expression 'wLogoWidget' [null] is not an object.
2022-12-15 16:19:24.112 [WARNING] :: Stack Trace:<anonymous>()@/Users/xxx/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_83712/scripts/3d universe/limb stick/3du limbstick g3+8.dse:149
2022-12-15 16:19:24.112 [INFO] :: Error in script execution: /Users/xxx/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_83712/scripts/3d universe/limb stick/3du limbstick g3+8.dseThe first time I installed it via DIM, found the LimbStick in the Smart content section, installed it again within Daz Studio, and added it to the script tab. Then I uninstalled it both in the smart content and DIM, and installed it again. Then I uninstalled it and installed it in Daz Central – still the same. Also, I have the impression that the files I installed at the beginning are left in the content library even after uninstalling. I even tried reinstalling Daz (in Daz Central). Nothing seems to work. I guess I can try installing it manually, but as a newbie, I'm unsure which folder I should choose for unzipping. There are plenty of tutorials for 3rd party clothing and hair assets, but I'm not sure if the LimbStick should have the same directory – I really don't want to mess anything up. Also, as it's available on the official Daz website, it feels like it should have been doable in Install Manager.
According to the log it iss till installed through Daz Connect. Right-click on the product icon/container and select Uninstall to get rid of that.
Thanks, I've deleted the files. But what is the best way to successfully install the LimbStick and run it?
Limbstick ErrorOh, I have a similar problem.
How to disable auto apply morph for Alistair?Please remember to put the Viewport in Smooth Sahded mode if you are going to show a nude figure.
Alistair's morph was fixed - redownload and reinstall through DIM, daz Central, or Daz Studio (depending on how you get your content).
Daz Studio InsallationDaz Studio can be installed using a stand-alone isntaller, but mixing methods is not a good idea so I would suggest installing Daz Central (or Install Manager if you want to customise the paths rather than justs et a base location) first, then using it to install the application and plug-ins.
Daz Studio InsallationIf I remember correctly, Daz Studio needs to be installed by either Daz Central or Daz Install Manager so you would need to install Central first if that is your preferred installer. That does seem to be backed up by the fact that the link to "Download Studio" on this webpage redirects to the download Central page.
Congrats on the new computer :)
Daz Studio InsallationI am gettng a new computer for Christmas. My question is, do I install Daz Studio and then Daz Central.
Holiday Giveaways 2022!riuken1 said:
Any one is having problems with the product show in the DIM or Daz central, it show that I buy the product but not show in the installers.
Yes, same here; I downloaded and installed it manually instead.
EULA Update & Editorial Licenses Coming to Dazkyoto kid said:
..I dumped the Cyber Racer and the asked for a refund on the Retro Apartment Props 2.
What other ones are there?
I was asking you about that in the case there was more of them.
I have already put those two in my blacklist and I will never buy anything related to them. I'll also totally stop purchasing stuff from here until there's a safe, secure and clear way to avoid Editorial Licenses with ZERO risk of getting one of those by mistake.
A strong store filter, a clear marking in the promo image, a clearly visible and non-missable banner in the product page and a reminding popup asking for confirmation in the checkout page are a must in the store, and not just one of those but all of them must be there together. Also a clear separation and marking in the DIM, in Central, in Connect, in Content and Smart Content panes after the purchase of those products is a must.
I'm sorry for those PAs who works hard on those products but, personally, I definitely can't have editorial licensed stuff in my library.
Holiday Giveaways 2022!Any one is having problems with the product show in the DIM or Daz central, it show that I buy the product but not show in the installers.
55th Bryce Contest ( Clocks / Overtime )Drachenlords, like your Lost in Time. The lady's old attire, the cool clocks swirling around the scene. What is at the woman's feet? Is that another figure?
Hansmar, nicely done. The central clock is excellent looking...like a spider.
New! Novica & Forum Members Tips & Product Reviews Pt 14I'm having a lot of fun with the aquarium webcams across the U.S. Take a peek- and there's links to the other webcams at their location.
For Monterey Bay Aquarium, start with the jellyfish. All cameras are live at the moment throughout the US then at night you can watch the recordings from the day if you missed them.
And right now (2:20pm Central) the divers are in the shark tank. They will post when they feed and get in the tanks on some of the sites.
Here's Aquarium of the Pacific webcam page.
My fav- the Puffins at Georgia Aquarium. They're not always in frame but then suddenly they'll dive in right in front of the camera. I named one Alfred LOL.You can go to the home page for the rest of the webcams. :) Enjoy!Need help with reinstalling filesWould it be possible for someone to write a small, very simple manual for the DIM? We need to have a clear guide to the folder structure. And the reasons why we should not mix download methods. In the earlier days of DAZ a content history could be purchased in a disk. That was a "lifesaver" for me. DAZ Central is nice to look at but way to slow and unmanageable. And Daz Connect? No thanks.
Looking for handbra and breastfeeding poses for G8FI am having the same difficulty in finding Richard's poses in Daz Studio as I was with the product that Saxa led me to. However I've just realized that I don't think I'm looking for them in the correct way, so I'm going to start by asking about that instead of about whether I'm installing them properly.
The directory path in the zip file for Richard's poses is "People\Genesis 8 Female\Poses\ChestnutP\G8F Hand Bra". Forget for the moment about where I am supposed to copy this "People" folder to on my computer, and assume that I have done it correctly. Given the names of the subfolders as shown above, and given that we're talking specifically about files for poses (as opposed to files for morphs, figures, clothing etc), how would I go about accessing these poses?
If you think that's a stupid question, read the rest of this post. If you don't want to listen to me ramble, you can stop here and we can see whether answering that question solves my problem.
Either way, thanks very much Richard for making those poses for me!Here is why I ask this. For poses from products that I purchased in the Daz Store and downloaded and installed using Daz Central - that is, the ones that I am able to access - there are three ways that I know of to access them. One is by going to the "Smart Content" tab in the left pane, and scrolling to or searching for the product in question. Most of these products have a nice fancy cover icon, but I'm not sure whether I can expect to find products like Richard's in the same manner since it's not a "real" product. If I could, I would guess that I could find it in Smart Content tab under the name "GF8 Hand Bra," or possibly "ChestnutP"; but I'm not sure whether I should be expecting to be able to do that, and in any case it's not showing up in that way.
The second methood is by going to the "Content Library" tab, aslo in the left pane, expanding "Products" and finding the product by alphabetical name. As with the first method, I'm sure sure whether I can expect to find the poses in this way since it's not a "real product," and, again, I'm not finding them.
The third method is by going to the Context Library tab and searching for the pose in the search bar at the top. This method, I would expect to be able to find the poses so long as I have installed them correctly; however, I don't understand how the search terms correlate to the pose files. Searching for more words seems to increase the results rather than narrow them (suggesting that it's looking for any of the terms rather than all of them), so trying to find either a product or a pose who name consists entirely of generic words like "G8F Hand Bra" or "G8F Default Chest Full" seems doomed to failure; but also, searching for a word pulls up files that don't have that word in their name. For example, if I search for "bodybuilder," I find all of the posing files for Z Sexy Bodybuilder, but many of said posing files don't actually have the word "bodybuilder" in their name, instead having names like "Z SB Btm 01 G8F." So again, assuming I've installed the files correctly, how should I expect to find the poses I'm looking for?
daz to blender install on MacBook pls helptothmilla said:
hey there !
i checked every forum and i really dont know whats going on at this point . i installed daz central and tried to follow tutorials how to be enable the add on in blender but first i think my zip file was somewhere else but most importantly when i try to import and i supposed to have a blendenr file in my library . i dont have it at all...so i just cant find it how to import that zip to be able and why i dont have blender app file at all? please help thank you xx
Install that through DIM (Daz Install Manager), it will install the Blender Part with Blender and the DS part with DS (and remember to follow tthe instructions on how to set it up on blender.
daz to blender install on MacBook pls helphey there !
Smart Content bug / locked@fladfisk147, You are better off with Daz Install Manager, Daz Central is too problematic.refer to this thread:
https://www.daz3d.com/forums/post/quote/426171/Comment_7804186
Also lokk at this topic:
https://www.daz3d.com/forums/discussion/601121/how-to-update-daz-studio-to-4-21#latest
You should use the Content Library instead of the Smart Content.
Click on any of the categories, it will expand and you can find anything you like.
Hope this can help you.
If you have some doubts post your comment, someone can assist you.
