Does Skin Builder 8 for Genesis 8 Female work with Genesis 8.1? (Solved: It doesn't)
Not directly, no. The two main limits are:
- The script itself will not run with G8.1 selected.
- It only supports the base Genesis 8.0 Female UV set.While you could process skins using that UV on on G8.0 first and then transfer them to G8.1, the product cannot be said to fully support G8.1 Female.
Has this happened to anyone else?First, your image is most likely to get deletd due to the textured nude figure.
Beside that: you most likely have a character morph which has been saved with a non-zero default value, so it always loads with the base figure.
Try the procedure in this post to fix it: Every character I have loads with unwanted extra morphs by default - Daz 3D Forums
Vo Yonina for G9 mouth morph is always active.jd641 said:
CS reported back that they were able to reproduce the issue and will report back when there's a fix.
It doesn't seem like there are too many people who have Yonina but just in case someone buys it before a fix is out, DAZ is aware of the issue now.
I guess I misunderstood your issue when I asked my friend if she had that character and to check. I assumed that being active there was a noticable difference in the look because of it. Yes, hers is active all the time as well, but you can't see it unless you actually go and look for the morph dial being on since it doesn't really change much. Anyway, good CS caught it so hopefully the PA can learn for next time..
HH Belle for Genesis 9 [Commercial]Is anyone else gettig affecfacts like this all over her body at SubD level 3+? They're strongest in the body morph, but are also slightly there in the head morph. Also should the fingernails look like that?
Cloth with Unity Cloth component works in Editor,but invisible in built game!charles said:
Have you asked on the Unity forums? More information is really needed to make any kind of educated guess. What was your build target for starts? What version of Unity? Did you unpack the materials and textures? What method did you use to transfer? You will need to double check and also be specific about the the shaders in Unity used.
Thanks. yeah i dont get it either. And whenever i ask in Unity forums i never get responses. Ever. Build target Windows cause it's for myself and i use Windows 10. I use Unity 2021.3.16f1( LST). Unpack materials and textures, what is that mean? i import them and then apply them. Originally with Unofficial Daz to Unity bridge the shader is Daz specular, but i drop another material one to all my daz clothes, which is HDRP/LIT .
You asked what method i use to transfer..Yeah it's Unofficial Daz to Unity Bridge 1.2 to transfer Materials..... But for the actual skirts i use DAZ to Blender for decimation and then Blender to FBX for Unity.
Cloth with Unity Cloth component works in Editor,but invisible in built game!Have you asked on the Unity forums? More information is really needed to make any kind of educated guess. What was your build target for starts? What version of Unity? Did you unpack the materials and textures? What method did you use to transfer? You will need to double check and also be specific about the the shaders in Unity used.
HH Belle for Genesis 9 [Commercial]FSMCDesigns said:
I saw Belle was released and had a question. Does she come with a browless texture option? I find the brows a bit too thick for my tastes and wanted to use other brows for her
Yes, all the makeup and mats do not include baked in eyebrows so you're good to use whatever eyebrows you want. Only note is that the "Eyebrow filler" options uses a mask shaped to the default G9 eyebrows (which Belle makes use of but with a custom morph). So if you want to use the Eyebrow Filler options, you would just need to edit the mask image to match the shape of the eyebrows you use. You can find it under the makeup option on the face material.
HH Sayble for Genesis 8.1 Female [Commercial]black_angel_x said:
Herschel Hoffmeyer said:
black_angel_x said:
I always waited for the matching char out from Mystique 2, sadly the Model delivered isn´t as nice as the Mystique 2-Version. I mean the Mystique 2-Version hat that special touch between natuarl beauty and beauty idealized but now it just look like the beauty idealisazion was overdone. I kind of hope the real Mystique 2-Version will come out too. just my opinion.
Outside of the breasts, all the details in the Mystique 2 character are actually turned up (for the body) and the face was not mine. Her skin tone is more tan. Is it mostly the body or the face we're referring to? I'm just confused and trying to narrow the reason. I think someone prior to you said the same thing that all dials are turned up on Sayble over Mystique character. Like I said, outside of the breasts, all dials are about 60% of that character. The breasts in the Mystique character were the included breast morph in the Mystique 2 line.
Sorry for resurrect this, I hope you dont mind, but I didn´t found a way to contact you outside of the DAZ-Forum. Thank you for clearing this up for me, it´s like I suspected, a different face and I still searching for that.
Last year was a little bit rough for me, so I was occupied with other things. Can you give me a hint where to look for it, somehow I seems I saw this face before but I can not make out where, it just bugs me ;-)
BTW: I realy like all your work here, you are a great artist and if I find/get the matching face, I promise I buy Sayble too, just to appriciate your work on it (even if the body was not that important to me) :-)
I was able to find one of the saved daz files on an old hard drive. Face morphs used in Mystique 2 Promos (except Honni 8 image which is Honni 8):
I'm looking for this girl angels-secrets-lingerieDaz handles customer support, so you could open a support through Daz, but if this is a custom morph that the PA uses for promos, they're very unlikely to release it. It does look rather like Pretty3D's characters, though, so maybe Pretty Base will suffice.
Freja 9I opened the boat up first thing and tried to see if there was a morph to get rid of it, but couldn't find it. And if I was out in open water when a storm blew-up, I would not want that tent over me, because if you need to bring down the sail, that tent will get in the way, or trap water in the boat, or just help a wave flip you over.
The problem with anything ancient that was a textile or leather, is that there is precious little that survives to the modern age. As one website I was reading noted, what is found is generally the best items a person had, not everyday wear. I understand now why Sutton Hoo was such a great find. I actually lived down the street from it when I was stationed in East Anglia.
I'm looking for this girl angels-secrets-lingerieIt looks like they've been using variations on this character since at least G2, so it's probably just a custom morph.
https://www.daz3d.com/celestial-poses-for-genesis-2-female-s
Genesis 9lilweep said:
Serene Night said:
Still waiting for masculine content to drop. We've had a ton of female stuff, but in order for me to invest in g9 I really need a ton more morphs, a way to import my existing g8 characters and better male muscle morphs.
i imported all my g8 morphs to g9 pretty easily using the G8 Clone for G9 and using transfer utility (transfer morphs only, transfer Favorites only)
unfortunately, didnt transfer rigging, so just need to remember to 'adjust rigging to shape' after dial spinning any of my G8 morphs on G9.
I transferred the things I wanted to genesis 9 but I find native content works better, plus without the hd it isn't the same look.
slow down gen 8 famLAG while posing seems to be a common theme over the past couple of years, I do wonder if it's the poor IK system that's the cause of it.
You don't have long load times, your log shows the base G8F loads in 45 seconds, there are people around here that would kill for load times that short, as it takes them 15 minutes or more to get the base G8F to load.
Almost all of those errors are down to you not having the Head Morph pack, the Body Morph pack and the Expressions pack installed.
AIUTO...CHI CONOSCE L’ITALIANO? PARTE TREDICITiziano said:
Imago said:
Tiziano said:
Peccato che queste siano in un formato che non posso usare.
Che formato è? Spesso e volentieri Carrara o Blemder possono aiutarti. E poi trovi bizzeffe di servizi gratuiti di conversione online, basta cercare "3D format conversion" e sei a posto. Essendo un semplice prop non devi preoccuparti di rig o morph.
Il formato è .dae.
il DAE è importabile in DAZ|Studio e anche in Blender, per dire
Il formato è .dae.
Apply custom morph without distorting clothesYou might need to create a projection morph
Apply custom morph without distorting clothesIt sounds as if the morph is baking the figure's displacement in, though I am not sure why it doesn't then move the whole figure on application. You should have as few modification as possible applied to the figure when creating morphs.
Request: Please List Products Used in PromosOpen request to artists: can you please list the products you used in your promo images?
Example: you make a model named Jane Doe for Josephene 8 and use Haydina Hair, Classic Bikini, and Sparkling Jewelry in the promo images.
Would it be possible to actually put IN the notes Haydina Hair, Classic Bikini, and Sparkling Jewelry?
I ask because there are a lot of characters where I want to buy the character AND the hair in the promo, but I can't find the latter.
Here's a good example:
https://www.daz3d.com/samantha-for-genesis-8-female
I have the character. What's the hair? Who knows?
The same goes for hair packages. On a scale of 1-10, I think the model used in the promo image is 12 beautiful.
https://www.daz3d.com/alyssa-ponytail-hair-for-genesis-8-females
What model is it? Who knows? Is it a custom character that doesn't exist anywhere? Is it one that exists on a different site?
It's one of the reasons I love Sabby's stuff over on Renderosity -- 99% of her character models list everything used in the promo images, so I can put together the whole set instead of just a bald, naked morph.
I'm not the only one who would benefit. In the couple of weeks I've been here on the forums I've seen at least a dozen threads to the effect of "can anyone tell me who this model/hair is?"
Just a request from a humble customer. :D
Thank you!
